Capacitor Mod & Transparent Mod done for Apple IPod 5th Generation
heyyy, how did you replace those capacitors? also, can you share the guide on how to change them? What is the difference in sound quality?
Yes I have. ELNA Silmic Audio Grade Capacitors. Iflash.xyz quite a good write up on how to change the caps.
When it comes to sound quality, I believe there's slight improvement in the bass or it could be just in my head. 😆
