Recommendation on VFM QLED (55 Inch)
kajha83
Kolkata
Hi All.
Looking for a 55/65 Inch TV for living room to watch regular OTT and DTH content. Viewing distance is 10-11 Feet.
Budget is around 40-50 K. Location - Kolkata.
Inclined towards QLED.
And observing a steep increase in price from 55 to 65. So, may settle for 55 Inch.
Based on other threads seems Hisense U6G is a sensible choice.
Any feedback about other brands like:
Vu Premium
Vu Masterpiece
Mi Q1
Toshiba
TCL
OnePlus
Any other advise / suggestion?
Thanks in advance.
Kamal
How is Samsung 55AU7700 for 45,000?
And how does it compare with LG 55UQ8050?
I can speak about only Samsung and TCL.
- I have TCL 615 (2020) model, i am happy for the price i paid. Android is slow. otherwise able to pull good HDR10 Content. So suggested TCL 635 series. Good VFM QLED
- Samsung I have QN90B series, but not in your budget minimum you would need to shell 90k for QN85A 55inch.
- 55AU7700 - Should be fine. At least I would be biased to Samsung.
LG I am don't prefer, but its my personal choice. unless buying a G2 OLED. 2Lac+ model
U6G - Heard great reviews.
thanks,
Kannan
Leaning towards TCL.
65P635
Any word of caution?
As a TV/Panel should be excellent VFM... may be dont trust android.. Buy and use and may be down the lane need to invest on FireStick or something else for smart functionality and good OTT... Since have seen TCL not updating OS properly..
But not getting QLED models in 65 Inch (C635 or C715). Getting 55 Inch.
In 65 Inch, getting the UHD model P635.
While initially, I stated that I may compromise on size, I am now keen on getting a 65 Inch even with regular UHD Panel.
Reliance Digital Kolkata quoting 48K.
Does it sound reasonable?
Check Amazon , you will get c825 at 89990.
Price I cant comment.. Usually Chroma/ Tata is very competitive in south, if you go with a online price they will be able to match less or same. If gaming is not a prio 635 should do..
Hi I am looking for a 55Qled. Ordered TCL C635 from Croma for 50k plus 2 years extended warranty but delivery taking quite long. Am looking to cancel and considering
Toshiba M550LP or Hisense U7H.
any suggestions?
More than PQ I am also looking at SQ so that I can stream music kn YouTube music or Apple airplay for casual listening. My TV viewing is less that 2hrs in a week and this one will be replacing an ageing TCL UHD.
Hi All.
Vu Premium
Vu Masterpiece
Mi Q1
Toshiba
TCL
OnePlus
Thanks in advance.
Kamal
In your list 2nd one true masterpiece 55inch VU glo masterpiece television
Hi All.
Vu Premium
Vu Masterpiece
Mi Q1
Toshiba
TCL
OnePlus
Thanks in advance.
Kamal
In your list 2nd one true masterpiece # VU glo masterpiece television 55 inches # in my personal opinion best value for money ( good quality black & rich colours ) original picture attached
