P-3A amp build
Akaudiotech
Coimbatore, Tamil Nadu
HI all, As a long time dream, I am trying to build a Rod Elliott`s P3A power amp with tone control and phono stage. Finally I bought the PCB form Elliott last august. But there was not enough time and money (for components and other parts) I postponed the project. Last month I restarted the project and ordered components, parts and accessories. The Initial PCB work is now complete and I would like to share you the progress of the amp. Comments and suggestions are welcome.
PCB
1. P-3A Rev A Power amplifier
2. P-05 Preamp power supply
3. P-06 Phono RIAA preamp
4. P-33 Speaker protection circuit
5. P-39 Soft start
6. P-97 Hi-fi preamp with tone control
Yes, you're right. I intend to use 25-0-25/500va toroidal for driver stage and 15-0-15 R-core for line level.
What is the VA rating of the 15-0-15 R-Core? What is the largest possible VA rating R-Core that you can fit in or on the chassis?? Now is perhaps the good time to plan to oversize it to the maximum, as per Indian Ears' post. Shilchar, etc.
Hi, the VA rating that I've choose 39VA from A.M. Technologies. BTW, thank you for your point out.
Hi all, Sorry for my late updates. Because some parts arrived (Ie vu meter and driver board) recently, and were delayed in customs. Almost assembled. It will be completed soon. VU meter from china and logarithmic driver board source from www.vumeter.eu from Lithuania.
Acrylic panel, Actually this`s my third panel of this project. Partially fixed.
Congratulations on great build. Please can you put up the BOM and links of where you sourced the parts
BOM sent by PM. Regarding parts that I've sourced from..,
Metal film Resistors and Wima Caps from the audio crafts. Few resistors and Electrolytic, semi conductors from in.elemen14.com (please ensure that you have registered GST). Connectors and other parts from sharvielectronics, Bangalore. PCB directly from Elliot.
Akat
