I was being very seriousYou just described all of humanity.
It makes me so happy to hear a human say this about themselves. Even in jest.
You won't find anything measurable with a umik - 1Guys! Everyone!
For clarification - I want to understand - "perception of audio change" will be reflected in measurements or not? That is all.
No need to bring out the big guns!![]()
Amir aadmi hai woh.I know a guy who became rich just by measuring distortion and sinad![]()
Every INCH of wire in a good system is audible. You will certainly NOT see it with ANY microphone. Just use your GOD- Given ears. HEAR IT !!!! The degree to which would hear it will be a result of just how well-thought-out one's entire system is.Hi all,
Let me start by saying that I am not sure if a power cable makes a difference to a system. However while having a discussion with a friend who is visiting me soon with his Chord Qutest, the discussion came up and he is bringing his Furutech roxy power cable (that with god's blessing will hopefully fit on the Genelec) to try with my Genelecs to see the impact. Sadly he has only 1 but that should be enough I guess. He is also bring his Umik 1 microphone to measure.
The question is - If we take a close measurement with the speaker position fixed, and change the power cable and ignoring what we hear, the measurements should ideally be different to show that the cable made an impact? Not looking for a flat or "ideal" graph, but just looking for changes in measurements with cable change.
*** Has this experiment been done before? If so, can someone point us to it and save us a lot of time
Thanks!
ME TOO!!!....So I guess I am blessed that I have one less thing to worry about in the quest for perfection, power cables...
Or, like the old chestnut bandied about and which goes: "The rig is just not resolving enough"SO I can very comfortably say, my ears are not trained or attuned or good enough to experience the "fine differences" that power cables bring. NOTHING.
OK, to set the cat among the pigeons: Which custom cable did you compare against?So I guess I am blessed that I have one less thing to worry about in the quest for perfection, power cables![]()
I would agree - For me the easiest difference to identify is in this order -This doesn't mean I cannot differentiate different source, amps and Speakers on how they sound.
I guess with my "auditory limitations" I can live with thatOr, like the old chestnut bandied about and which goes: "The rig is just not resolving enough"![]()
Made these myself - got some fancy power connectors - "furutech looking - fakes"; a thicker shielded power cable -Aucharm PPC 4.0. for speakers & sub & finolex for the Xbox & CXNOK, to set the cat among the pigeons: Which custom cable did you compare against?
Your music system is for your ears , so what others say does not matter. Its good if the system is agnostic to power cables as it takes one of the moving parts out of the equation which makes it simpler to get to your sound !Request all to read this as 'my observation' not an attack on anyone's belief or experience.
What did you upgrade to for each of them?I recently upgraded my dac, speaker cable, power cables, digital power cables, and power distribution box.
I believe this is the reference! - https://www.hifivision.com/threads/upgraded-my-power-cable-a-review.92780/#post-1035347What did you upgrade to for each of them?
I agreeEvery INCH of wire in a good system is audible. You will certainly NOT see it with ANY microphone. Just use your GOD- Given ears. HEAR IT !!!! The degree to which would hear it will be a result of just how well-thought-out one's entire system is.
Seems like no one on HFV newly uses " TRIOS", so you are all behind the eight ball right there !!! Goodness knows how many other optimization areas might be similarly overlooked . Maybe you need to let your friend invite you over to HIS set up !!!! No mics needed, just employ what is on either side of your head. :-
Is that the SoundFoundation Power base?I guess with my "auditory limitations" I can live with that!!!
link for connectors - https://theaudiocrafts.com/cables-and-plugs/power-plugs
So the total cost per cable was around 4K approx per Speaker, & the sub was lesser, shorter cable.
See I expected no differences I just wanted them to look FANCYView attachment 77492
Yes!Is that the SoundFoundation Power base?
