umangloria
Hi All, I am glad to be here.
I will have an untreated room (14*11) and a hall (16/18 * 11) on the upper floor of our new penthouse. I am planning to build a complete setup in either of them, mostly I will go for the hall my end goal is 7.1.4 if that is more enjoyable and suitable for the space or I can stick with 5.1.4 or 5.1.2.
Components I have selected:
AVR: Denon 3800h
Fronts: QA 3030i
Center: QA 3090Ci
Rear: QA 3020i 0e 3010i
Atmos: I haven't sorted or listed anything yet and also ceiling is hard concrete so any suggestions on which speakers work best for that and mounting information will be super helpful.
Sub: I am still exploring
Note: I currently have a max budget of 1.8-2 lakh so I am thinking of getting AVR + FRC for now and keep adding components as budget allows later.
Questions:
Thank you in advance
AVR: Denon 3800h
Fronts: QA 3030i
Center: QA 3090Ci
Questions:
- Is 3800h overkill for the room size and selected speakers ? If yes any other recommendations, I like movies and music equally.
- Is 3090Ci enough or good for the center channel
- Should I opt for 3010i or 3020i
- Which configuration I should go for if I am setting up in the hall?
- Please suggest sub
- After bargaining I got the quotation for above mentioned components below from Hifi Gallery: https://maps.app.goo.gl/j6XGKLjcrDhp87yj7
- AVR - denon 3800h - 115000 , marantz 6015: 110000, 2700h: 68000
- 3030i - 38k (Not sure as I was mostly discussing AVR till this point)
- 3090Ci - Not sure
