Technics M6 Mk2 Cassette Deck-HELPšŸ™šŸ¼
Vin4life
Australia
Hi all
I am new here
šŸ‘‹
I need some help with replacing the belt on my
-Technics M6 Mk2 Cassette Deck
Canā€™t find any information on what size flat belt is for the motor?
And
The light lamp and VU power meters are not functional?
Lamp soldered!
The only thing is functional
-Turn on
And
-Motor is spinning well
when played or F/R
Help would be greatly appreciated
Thank you so much
Welcome aboard! Glad to have you here.
Good luck with your search. Hopefully someone on here might be able to help.
What happened to the old one? Can't you measure it?
The following assumes a lot of these stuff in the documents I'm using is correct
RS m6 manual says belt is qdb2019
Russell PRB belt cross reference book says that matches to their frw10.1 model
Frw 10.1 spec is
Internal circumference 10"
Cross section 0.12"
Wall thickness 0.023"
Hi greenhorn
Thank you for your response
The belt is snapped
And V meters and lamp not working
I am not sure why?
I measured it its
27.2cm length
Around 3mm width
Around 0.5mm thickness
I am not of s good health
Itā€™s draining mešŸ˜”
Hi greenhorn
The belt is snapped
I am not sure why?
I measured it its
27.2cm length
Around 3mm width
That measurement is for the motor belt
Where do i buy the parts needed!
Here is link for belts on Technics RS M6 Mk2 i have installed in 2022 They delivered in 7-10 day in India
Link for Bulb replacement
Link for installed Bulb
Hi Spancal
Thank you so much for that
How did replace the light bowlb
Thank you so much
How did you install the Bulb , as the one on is stuck and soldered
Or dose it just pull out?
And when i switch on the deck
The only thing that works is the motor
The VE metres donā€™t function
Or do they come to life after i put in new belt on the motor?
Bulb is connected to with wires to PCB of VU meter you have to solder it
Before that change the capstan belt if cassette plays then VU meter will move.
Also spray contact cleaner in record playback switch on main PCB .
If you have DIY soldering skills then do otherwise you have to give it to service person.
-The light bulb comes without housing, or do i get T5 socket housing ?
I find a website in AU stocking the bulb you recommend
Please see picture
How do i get the PCB out to get to the Playback switch?
Do i fully unscrew the front of switches screws?
Please see picture
And does the Playback Head look healthy enough ?
Please see picture
Thank you so much
More pics
More pics
The Head looks little bit rusty due to storage First clean it with IPA 99% Then Take Autosol ASL_POL Metal Polish clean it with Q tips it will look shiny
Fully unscrew the front of switches 2 screws Remove ,Remove Remove 2 screws from PCB then remove Tab holding RCA wires You will get PCB out to get to the Playback switch
Use 6v 200mA Bulb in deck it comes with wires not 12v like shown picture
Ok thank you so much for that
Greatly appreciated
Do you know by any chance where can i get replacement
-VU meter Lamp bulbs for
Technics SU-Z2 Amplifier and
Technics ST-Z1 Tuner
Its part of the same stereo system
I am trying to get my whole stereo running for my son for Christmas
Greatly appreciated
Read and search what is voltage written on the bulb on net and replace with equivalent value bulb
Actually these bulbs are old stock very hard to find
I have only deck ,Please share video of full system working after restoration
Nice system :)
Nice system :)
Sure i will
I have been reading and i canā€™t find anywhere, where to get this bulb or there valtage
The only thing that is says on the bulb is H8v thats it
No other info šŸ¤Æ
Nice system :)
Sure i will
I have been reading and canā€™t find anywhere, where to get this bulb or there valtage
The only thing that is says on it is H8v thats it
Other question
The cassette deck face plate came out nice and clean
But the plastic part where you put the tape didnā€™t
Is there any trick to make it in batter condition?
And the cassette buttons for play,forward etc
How do i clean them?
Please See pics
Thank you so much
Sure i will
Other question
Please See pics
Thank you so much
Clean and polish plastic part ,knobs and face-plate with Autosol ASL_POL Metal Polish
And Buttons you should Repaint with Original Silver or Grey color
I got Autosol Aluminium polish
Disent do much
I think i have to get the Autosol Gold one
I have been trying really hard to fund the Light bulb Valtage and size for the
Technics SU-Z2 VU meters
Is it possible to help me ,please find that
As i have ordered everything else accept that
Thank You for recommending Autosol ASL_POL Metal Polish... I used it to clean the key button block on the front panel of my Akai GXC710-D Cassette Deck. Looks great!!
Oh thats good to herešŸ˜Š
Are you very happy with your Akai 710 cassette deck?
As i was actually looking of getting one of the same model !
