Floorstanders for 5.2.4 setup
I had OWM 3 with MA Silver 500. The Polks were underwhelming. Replaced them with Monitor 50. Much improvement. You could just use the 50 and crank up the surround channel levels and see if that works for you.
Please share the prices also at which you are getting all these gears if you don’t mind. Also are you sourcing it from local vendor or from outside?
