Recommendations for LCR for Home Theatre
ElCapitan
New Delhi
Hi All,
Looking for your expert recommendations for LCR for my Dedicated Home Theatre (Size 14X12) to upgrade my aging B&W CM4 set.
I've shortlisted :
1. Q Acoustics 5040 and matching Center 5090, (I feel the centre to be a bit lacking from the specs and reviews)
2. Wharfedale Evo 4.2 (Stand Mounted) & Centre Evo 4.C
Any other suggestions? Looking for something that is good Value, budget of Rs.2-3 Lacs.
Gear List:
Sony VW-290ES 4K Projector
GrandView 133” 16x9 fixed screen
Denon x4700h receiver
B&W CM4 LR & B&W CMC-Centre ( Oldest part of the kit, Need to Upgrade this)
Klipsch Bipole surround speakers
Dali Alteco C1 as 4 Atmos speakers & 1 Voice of God.
SVS PB1000Pro
Apple TV4K and Zidoo 9XPro
Check XTZ M8 THX Speakers that can be used as LCR.
JBL Synthesis speakers
Arendal MONITOR THX series are good but they are very expensive
Thank you for your suggestions!
The XTZ M6 THX is the only one that is in my budget though!
Any one that has any experience with the QA 5040 or Wharfedale Evo 4.2 or 4.4?
Hi good luck for new gears hunt..
i had 5030 FS last year its good value for money speakers..5040 i heard small bit of renowned improved tuning in their cctry.
before u take decision , can you try Indiq audio an Bangalore based Company. Sound is individual choice i felt this audition may give you some more clarity & if that helps in deciding ..
try your luck & good luck hunting better speakers & set up
