DAC Delay !
I was reading a review of this DAC on 6Moons and it looks like you will somehow have to connect the DAC to the computer, possibly by using a USB/Firewire adapter. And then you will have to get the management software of the DAC and play with the settings (as alluded to by @keith_correa earlier).
Fireware as a tech, didn't fly. Doubt I will be able to source a fireware. It doesn't take in USB. Let's see. Will try all avenues suggested and report back.
After many months I took the Weiss again to try. Since than I have upgraded from Eversolo to Lumin U2 mini.
Strangely the delay (which was part of this discussion post) is no longer there. Same wires, same DAC just the change of streamer.
