WiiM PRO
Even if it is a slight step down, I think it is totally worth it. Allo system goes haywire after using sometime. I switched from allo boss v1.2 to wiim mini+ smsl d300 and couldn’t be happier.
exactly and then it needs a reset of the software sometimes.also sometimes after boot up its tricky to airplay
Nothing is more frustrating than a working allo spotify connect hiccup during music playback which was working fine for the last 30 minutes.
Anyone used the Analog inputs on Wiim Pro and then getting a digital signal out to an external DAC? What were your observations?
MaSh
ok made up my mind to go for the wiim pro plus.is there a great diff btw pro and plus vis a vis sound?
Wiim Pro Plus's DAC is considered to be better than the one in Wiim Pro. However, personally I would prefer to get the Wiim pro and keep the DAC as a flexi option.
MaSh
Has anyone tried wim pro with different digital cables (other than one received)and observed any difference in sound quality ?
Someone please enlighten. Why would I need a Wiim just to play the songs on my stereo setup when most of the stereo amps from Yamaha, Denon & Marantz have Musiccast & heos app respectively through which you can easily have wireless playback. Stereo amps also do have inbuilt DAC.
There is Airplay 2 also, Wiim is being marketed nonetheless. What SQ difference one would have with Wiim?
I checked with 2 guys in my circle and they said there isn't much difference in SQ.
Did anyone feel so?
I am using Allo Shanti, which again has two rails of supply,5V 3A and another 5
You mean 1A?
Even I had doubt about it , but ppl on wiim forum says its draws max 1.5 A and min 0.5 and p50 is just in middle of it. SO I think it might work
See here
@MaSh already using this.
Yes I did. I did mobile charger vs Allo Shanti and I felt soundstage a bit wider, darker background , crystal clear and a bit more meaty vocals and may be a bit tight bass(But it may be due to isolation applied under speakers too) with Shanti.
Hi Kumar which one do you recommend to use with Allo Shanti 3A or 1A.
I too have similar question. I have Apple TV (3rd gen). I was exploring the usecase for adding wiim pro. I do not know if there is something that wiim will add on.
Wiim positives (imo & ime)
+ remarkable connectivity (no drops, disconnections, no odd behaviour, works 99.9% time)
+ slightly cleaner midrange (if compared with direct airplay/spotify connect on AVRs)
+ easy setup, plug & play
Wiim negatives-
- not the best as far as SQ is concerned, even at the price they are being sold
- (I felt) warm tonality even with its digital out (supposed to be transparent)
- no wow factor in SQ
- look cheap/ordinary
- just okay build quality
Except the midrange, I found streaming through my marantz avr give me better sound than through wiim (through its coax out to avr coax in). I think should be treated as a nice solution to the old systems lacking the networking/airplay functionality) Apple TV with Avr sounds better than Wiim. Also Apple TV is now streaming bit perfect stereo, no more 48khz
