kartechnology
I am using NKB 5kva for approx 1.5 years. No issues so fa
Transformer in itself is a major factor in such equipments. Apart from winding material (aluminium or copper) , it's insulation, wire thickness, purity, core material and lamination grade etc decide the cost , performance and efficiency.
Like all the members here, I am also using NKB 5 KVA system from more than a year now. Never ever faced any issues. The system came in a solid wooden crate and was extremely easy to install by following the user manual.
Voltage here fluctuates anywhere from 180 to 250 but the system has always given constant output without even a trace of flicker and is dead silent....
They clearly have installations and service support all across the country. Even saw some excellent reviews from their overseas clients.
Numax system having major performance issues right away rightly raises questions on material quality IMO. It clearly wasn't built and tested properly before delivery.
Generally speaking, I don't think any company would be able to tag and sell their product at a higher price if their quality doesn't have substance. Sayan is right, NKB must have reasons behind their pricing.
in general one cant notice the voltage fluctuations unless
1. wifi cloud data logging is present in stabilizer - and the sync rate needs to be like every second(which i have) unlike their standard server which updates every 30 seconds.
2. monitoring the output voltage with some other device, eg. wifi connected solar inverter/ sonoff pow, etc to see any spikes/sags
3. actual output tested with a oscilloscope - best one
4. observing the tubelights / bulbs for slight flicker
there are times when the PWM is going off and restarting as per the device logs. in that time the output =input voltage. could be a DSP hangup. tech has told me many newer units are facing this voltage fluctuating issue. and yes, pasting a QC OK sticker on the cabinet isnt enough. one of the bolts on the heatsink for the wires were loose when the unit came. so ... i think numax is not the one even though cost is less...previously igbts used to fail itseems..now they replaced that with better ones and facing this voltage issue.
Currently Fuji Electric P2hf 40G120HD 31330 IGBTs are used in my unit.
tublights flicker corresponding to this..fan noise from solar inverter..the vibrating/buzzing from transformer
@funnyprogrammer what to do now..waiting for a new / replacement motherboard currently...suggest you to check the output instead of relying on the front display
