Home Theatre 7.2 Speaker
Yogesh2k5
Hi Everyone,
Need your help on finalising the 7.2 Home theatre set up.
I am setting the 7.2/5.1.2 Home theatre setup and this is first time i doing this and its been a month i have started exploring about the speaker and AVR's based on the research I have shortlisted the below Speakers and AVR and i would need your suggestion like which would better option and my HT requirement is to watch movies.
Budget is around 3 to 4 lakhs
Speakers :
1. Klipsch Reference series
2. Q Acoustics 3000i series
3.Paradigm Monitor 3000F series
4. wharfedale Diamond 12 series
Please suggest if have other models are better than above.
Subwoofer : Please suggest subwoofer which matches the above series or any model which is better ?
AVR : For Movies Denon is good option thats what i heard so far, please suggest marantz or another brand/model would be better option
Denon AVR-X2800H
Go with Denon 3800. 4L is a decent budget but need more details in room as well. Dimensions and if it’s dedicated or in living/Bed room etc.
Its 15ft length and 12.6 width... its multipurpose room.. living and Home theatre
You will definitely need a powerful sub. 15 inch ported or dual 12 inches. If no space for duals go for rythmik fvx15. Speakers go for the ones that have high sensitivity ratings.
