How reliable is the “speed test” for internet?
@Analogous
Try clearing Amazon Prime app cache to see if it helps.
The only way to clear the cache on the TV (LG CX) is by switching it on and off at the power outlet. This is what I do once or twice a day.
I read online that it’s possible to access a list of running programs by long pressing the home button and select the app to close. However this list does not appear when I long press the home button.
Thank you so much. This is helpful.
So is there a more reliable method to check the quality of Internet services that we pay for?
To continue: How come I am facing this lag/ freeze only with Amazon and not Netflix, Apple TV etc?
Ultimately, the "speed" at which you can connect to a website (or more accurately its server) is determined by the network between your home and that server. If the server is somewhere thousands of kilometers away, your speed checker has to traverse multiple transit points and possibly undersea cables.
If you run a test on https://www.speedtest.net/ , choose a far away server, say on the other side of the world and see how the results differ compared to when you don't choose anything. Not choosing anything chooses a default server which is usually in the same city as yours, resulting in higher reported speeds.
Content providers use "edge" points-of-presence (POP) - servers which are closer to you in terms of latency - to improve speed and thus your viewing experience. The app will automatically choose the closest POP.
I am not familiar with Amazon's network, but my hunch is that Amazon Prime might not have a good edge presence compared to Netflix et al which might be affecting your viewing.
How does this work? How accurate is this?
I find drop outs and freezes (only with Amazon Prime) happening occasionally over WiFi and immediately afterwards starting the Speedtest shows decent up and download speeds…
I can think of an explanation. Grateful for help and guidance on this
Try the bufferbloat test above. The test is at the extreme and may not be representative of your usage, however a low rating would give you something to look into.
Probably simplest would be to use speedtest.net and pick different servers in different locations across the globe AND also select single connection instead of multi, to see how your connection performs. Rerun at different times of the days and different days of the week, perhaps your ISP capacity is being over utilised at different times.
Also if your connection is copper coaxial that could also explain inconsistent results due to signal interference from things like power lines or perhaps radio waves etc.
BTW your location says US but isn't BT/openreach in the UK?
I just now discovered this !
In the same way, there are two units commonly used to measure internet speed: Mbps and MBps. That little b or capital B makes all the difference. Mbps means megabits per second, and MBps means megabytes per second. To convert MBps to Mbps, you just multiply by 8, so 1MBps equals 8Mbps.
My 60 Mbps shown on the speed test is actually 1/8 in terms of MBps…. Quite slow.
Never even noticed the capitalised B and small b in the reading displayed or knew that it mattered.
