Using audiolab 6000a as pre amp with more powerful seperate power amp .. advice need
subabu2002
ERODE , tamil nadu
hi everybody,
currently i am using Audiolab 6000a ( 50 watts )and Dali Oberon 5 speakers ( 150 watts )..
i am happy with this combo for almost 4-5 yrs.. but sometimes i feel bit small sound or lean sound for some songs.. if i increase volume levels,it sounded little hard to listen.. in low volumes , no problems..
so , i wish to attain better energy and bold like sound..
for this , i have one better offer for Quad 909 power amp from link.. that reproduce 140 watts.. no way to sample test with both combo.
audiolab 6000a have seperate preamp out , so i can use quad 909 external power amp..
if i use audiolab 6000a as a pre amp and quad 909 as a power amp, may i get better power than integrated audiolab 6000a s sound ?
read about audiolab 6000a pre amps output specs , that it can able drive quad 909 amp... but i dont know much experience to consider..
mostly i played songs via blue tooth with my apple i pad ( i tunes , youtube )..
is that good idea to add external power amp with excisting integrated amp?
or buying external matching preamp seperates or dac with pre amp will do best ?
thanks
suresh babu
hi everybody,
thanks
suresh babu
I am also using audiolab 6000a, i have changed power cord and its given good changes. Try to change power cord and check.
hi everybody,
thanks
suresh babu
I would suggest to first fix the source. Playing via BT on a hifi setup can be the primary reason for the leanness / compression you are finding. Something as simple as a WiiM pro / Allo Digione will make a world of difference vs your existing playback style.
@fLUX - lol, u beat me to the buzzer in pointing that out.
try a hard wired connection such as toslink from your TV first to see if you're happy with the improvements. If not, as @fLUX suggested, get a cheap albeit excellent streamer like the Allo Digione Signature or Wiim Pro.
Hi.
I have been using Dali Oberon speakers for several years. I would suggest pairing with a MArantz amp, rather than adding a power amp.
The Dali + Marantz combo works really well.
The amp I would reccoemnd is the Marantz PM7000N.
