Denon dp1000/3000 worth buying?
hifimaddy
kerala
I got some offer on Denon DP 1000 around 15K without the arm only the base plate. Is it worth buying? And the seller also has a dp 3000, which I have an eye on, but someone already booked it, but still it's not sold out.
Thank you 🙏
15k for a turntable from 1970's? Seems a bit much. Unless you have a desire to own one of these, I don't really see the point. Not exactly a collectible. You need to verify the condition too.
DP1000/3000 are great TTs if you like the DD sound and if found in good condition or if restored carefully by a professional. However since there is a lot of electronics, if you can't ascertain the condition, better not get into it. In general older Thorens/Garrard/Lenco etc are mechanical with no electronics and will last a lifetime.
Otherwise if you are a newbie, buy a modern TT.
I am very new to the turntable world. Without tunearms, this deal seems very useless, at least for me. But also one more thing. I have found a SL 1200 mk2 in good condition. Working fine. Asking price around 50k
Dp 3000 and 1000 are great, demanding DDs. The seller sold the DP 3000 for 30K without the base and turnarms. People are still ready to own this in their collection.😒😒
Hi, thanks for your kind reply. However, i don't know how old your vinyls are and in what condition they are now . But if they are in good condition despite being old , you can play them on your new TT and there should be no such issues. Most of my vinyls are old , some of them are even older than me but till date they are doubtlessly nice. While buying old vinyls , thoroughly check both the surface of the vinyl and see whether there are any visible marks , dents etc. Please also place your finger on the vinyl and try to feel if there is any crack . Please do not forget to clean them , let them dry and then play and enjoy.
It's very old vinyl. My father brought it in 1993, but it's from 1960, i guess, and some of them are broken in the sides. Only 3-4 are in good condition. At the moment, I don't have any phono stage. The one that I have makes a lot of noise. I am also searching for a phono.
Better not to play bad records to avoid stylus damage. BTW which phono do you have? However, if your TT has MM cart then you may try CNC phono made by FM Sachin. I have been using that phono and I am happy.
it came with ortofon concorde dj s which i am not so happy but i will change it later on.
WOW! That is a clean piece you got there. Only immediate change I recommend is a Cart. Get yourself a decent MM cart to start. Many videos on YouTube how to change a cart and balance the tonearm. Get yourself a decent phono as well to start playing some music. The SL-1200 MK2 is a legend of a deck.
I came across many, and they are all in a bad stage, and the price is too high. This one, lucky for me, everything is in perfect condition. only dust cover is aftermarket.
I like to get the Ortofon Blue, but at the moment I don't have a budget.
@Record Player @Bhaskar Jyoti Talapatra
I have a doubt. suppose I remove the tonearm or platter in any case and I can fix it back myself or need a technician to calibrate to its actual position? I heard calibrating tonetables will significantly increase the sound quality. Should I give it to some experts for an ideal setup?
The platter and the tone arm appear to be in good shape /position. Why do you want to change those?However, i think better trust an expert for calibration if you are a newbie. Reach out to FM @reubensm who has vast experience. He can guide you through.
Congratulation and welcome to Technics TT community. A direct drive at this price point is unbeatable- A S shaped tonearm with varied cartridge capability are hard to beat.
Get an Ortofon Blue or Shure V15 type IV
it came with ortofon concorde dj s but like to upgrade to ortofon blue in the near future
There is an old Russian saying (which used to be jokingly brought up when the MIR space station was in orbit) - if it isn't broken, don't fix it.
These decks dont really need any servicing or calibration, other than lubricating the spindle one in a while.
A Technics SL1200 (all models) can be stripped down to pieces and reassembled without any worry whatsoever. However, in order to do so, one would need some experience and the right tools. There are numerous YouTube videos on how to do so.
Getting the best out of a turntable is not difficult for average to good listening, but if you have higher expectations, the entire chain from LP record to speaker and room, comes into the picture. If you just want to relax and enjoy some good music on vinyl records, look no further than the SL1200 with a decent cartridge.
Denon DP 1000 and 3000 are direct drive TTs, yes but wait....
They use AC synchronous motors ensuring full speed ( 33 RPM or 45 RPM) in just quarter turn.
The venerable Garrard 301 & 401 also used AC synchronous motor but drive system was idler.
Story goes around that Nippon Columbia ( Denon ) designed the DP-3000 as an RIAA Broadcast Quality turntable.
It is built to run 24 hours a day, 7 days a week, in an actual radio broadcast station for years.
The motor torque is sufficient to bring the turntable to full speed within 1/4 turn from a dead stop.
DJs would back cue a record by setting the stylus into the groove, manually turning the disc until the music started, then turning the record in reverse 1/4 turn. When he announced the song, he hit the 45 button on the turntable, and that turntable was supposed to be up to speed by the time the music started. One quarter turn from a dead stop. That was a RIAA specification for a broadcast turntable.
So Denon DP 3000 is indeed a different beast.
