Lack of high frequencies
india
I have onkyo avr with taga harmony 5.1 and xtz SW. i am ok with bass but definitely miss high frequencies(chillness in voice and music). how can i improve? can i add tweeters in two front channels? Any expert opnion is welcome please
If there are tone controls in the Onkyo menu like as in Denon/Marantz, then increase treble from there.
I tried my best bro. But it lacks that crispness. i love that treble little on the higher side
Set the speaker size to "small" in speaker configuration and set the speaker cross over to "80 hz" . Try > 80 hz if it does not improve crispiness still.
Also try adjusting the speaker distances manually to higher value than that's set currently. Try above "14" or "15" feet or equalent "cms" setting speaker distances. this should improve crispiness.
Also You should have "bass" , "treble" control in older model of onkyo. u should be able to change it.
if your model is new then you should have Equalizer control to change the tonal control. For that u need to switch off "audyssey" or any other room correction available in your avr model.
Also try changing the different listening modes.
Thank you Bro for your reply. My fronts are towers. can i set them to small? My avr model is ONKYO TX-NR737
Setting up the speaker type to small, try some silver-coated speaker cables they might bring some spark to the upper mids and treble. Not by much, a slight improvement, yes.
