Which 65" OLED to buy
sacd77
Hi all, I am in the market for a 65" OLED. Have git confused between the LG C4 and the Samsung S 95. Any pointers to clear my confusion? Thank you in advance.
As an user of an LG OLED , I can right off tell you, that it most probably is the better choice. Also given that LG makes the OLED panels for almost all brands. My only complaint with LG is their limited choice of apps, and I was forced to get an Firestick to work around this. I understand that Samsung OS too, might have its own limitations. Good luck!
I’m in market for 65” OLED and I’m going with Sony Bravia 8, this after limited research I had done also the confident I have with Sony and past experience I had with thier product.If you are so specific with LG why not give a try with G4?
Budgetary constraints
