Building a DIY Subwoofer through a builder
Around 150 sq ft.
Not loud. The sound cannot be heard inside other rooms.
I have space only in the front left and right (behind the main speakers).
I have two pairs (RtiA8 and Cadence Arista)
thanks.
if its the cadence Arista you seek to reinforce, choosing an OB (h frame or otherwise) may actually be the right decision. the good news is that OB suitable speakers are normally cheaper (high qts means a smaller magnet)... as will be the construction complexity of an H frame
if its the polk RTA you want to reinforce, that's a different story, what do you miss in the polk Bass? clarity? the last bit of extension? (I had the RTI A7 for my home theatre many years ago so I am familiar with it. for the A9, with its 3 8" woofers, I would suggest that you consider bi amping it with the piano crossover driving separate amps for the mids +tweeter and the bass. (it might require rewiring internally) but it might be a cheaper intermediate step. if it doesn't work for you you could use the that amp to drive a dedicated Sub later.
thanks.
Yes, it is the cadence that I seek to reinforce and for the Polk I need the last bit of extension. Any drivers that can be recommended for an OB (h frame)?
I've heard OBs, but never built one, so never researched as to what's available. Hari Iyer or yogi bear would be able to guide better
for Polks, if its the last bit of extension, please evaluate using a boundary reinforcing placement or DSP before spending any money. IF there is a piano DAC in the chain, then there will also be an SBC in the picture as well. if you are using volumio, they have a very nice DSP stack now..
12” and 15” higher Qts from SBA..
Cheap ones are from GRS… Quite some choices from Parts Express. Quite some builds on diyaudio…
I am also making a DIY subwoofer with the 12 inch IWAI driver, I have decided to go with sealed as my room is small with about 100 sqft. and there will be room gains, so it will sound good enough I guess, as for the driver, high price does not always mean better performance, and the bigger the driver the better the low end is somewhat true, as an 8incher wont be able to physically match the amount of air a 12inch would be moving, considering they both are of similar specifications ofcourse.
I have already ordered the driver, will probably get somewhere around next week, and then 200 watt plate amp and a sealed enclosure from albin is what I have planned for now.
I have done quite a research on subwoofers in the past few days, I will try to answer your question one by one.
1. Should we go for ported or sealed?
Since your room is small, a 12 inch sealed would be enough, as there will be room gains, but then again going ported will enhance the extreme low frequency that can be good for movies. The issue arises with size mainly, as going sealed you can manage with a 45L enclosure, but going ported you will require a min of 65L to take advantage properly. Also, add to it the complexity of building, you will have to calculate the port dimensions and everything , which could mean that there are more chances of going wrong, you will need an excellent builder here to precisely mange the volume, port dimensions and length. You can use softwares like WinISD or Subboxlite, to design and check things.
2. Is very low frequency extension good (20 Hz and below)?
We humans cannot hear frequency below 20 Hz, going below that would mean basically the driver will move the air, you may not hear it but you will feel it. For music it is not required, for movies yes it will enhance the experience.
3. One or two subwoofers?
two subs will always have more power, but for 150sqft I don't think you would need 2 subs if you are going with a 12incher. Also you cannot have ported and sealed sub together, it has to be ported + ported or sealed + sealed.
4. 10" or 12" or larger (our music room sizes are probably roughly around 150 to 200 sq ft)
12" is the sweet spot, just go with it.
5. How much impact the driver has on the quality? So IWAI, Pioneer or SB acoustics?
You can simulate different drivers with WinISD and Subboxlite, each driver requires different size of enclosure to perform optimally, generally what I have noticed is that costly and better drivers can go low with small enclosure where as cheaper drivers need bigger enclosure to achieve that same freq.
Avoid any Car Sub, their driver require a very large enclosure, they are made specially for cars because they take advantage of the car cabin gain (room gain).
6. Class ABCDEFG (what kind of amp) to drive the driver
There are few options here, you can either go with Plate AMP, those are Class AB, or you can go with the likes of Fosi that will be Class D, now both should sound good, but AB will have more power.
7. Crossover details
If you are going to use your computer to drive these, then you can use VoiceMeeter to set the crossover, otherwise you should look for an amp with crossover settings, most plate amps provide that, and well the setting would depend on your speakers.
8. Any recommended builder?
These are some builders that I have come to know about
AlbinTech on youtube
DiptiElectronics on youtube
Audiofy.in also provides
I personally am waiting for my driver to get home first, so I cannot vouch yet.
Attaching specs and dimensions for IWAI, as you cannot find these on official page yet, you can use WinISD and similar apps to compare.
If you need more help or anything you can DM me, Good Luck.
Wow. You have given a comprehensive answer. Thank you for taking the time. Will wait for your impression once you recei e your sub.
Above is the SB Bianco OB350 for open baffle subwoofer build. But the site is showing they are out of stock sadly.
There are well documented OB builds with this driver if your goodselves google and see. There is one by Javad Shadzi and the bithces brew project that Iam attching here.
will this not be more suitable for woofer rather then subwoofer because the frequency range starts from 40 hz
Yeah its a woofer designed for OB use. How low it goes, will depend on the baffle size. Though I think its Fs is around 34 hz, there are ways to build H-frames and Diploe subs to lower the Fs even lower. If you google " the bitches brew project ", two of these drivers with dsp go to 20hz too. So its possible. But yes, it is actually designed to be an OB woofer, and is not technically a subwoofer because of its higher Fs.
Luckily I got a number from a memeber of hifivision, from there I messaged the iwai person and purchased it directly, it took some time as the driver was not ready they made a single unit and and sent it to me. And it costed me 9k inc shipping.
Can you share iwai details
