Touch Screen based low Noise Streamer using Raspberry PI
mbhangui
Pune
This post is an attempt to make people know about UNIX and also build a Raspberry PI streamer with the following attributes
  1. Touch screen based. You can do everything using the touch screen. Play a song, pause it, shutdown the machine. Increase or decrease the screen brightness. Stream Spotify or Apple Music, Play songs from your local hard drive or any drive available on your Network
  2. Connect a IR receiver Diode to the GPIO pin and control your music playback using any spare remote that you have. You can use your TV remote, Apple TV remote, cd player remote or any damn remote you may be having. If you have any TV tuner cards that you used in your HTPC, then you can also use the USB IR receiver. If you don't have a USB IR, no problem. We will buy a IR sensor costing just Rs 32.00 like this. There is nothing more handy than using an actual remote to control music playback. Using app based control isn't as easy as using a real remote.
  3. Control Music From this Raspberry PI devices on all existing allo, volumio, moode players that you may be having with devices from PI2AES, Allo, HifiBerry, etc.
  4. Have a power button to turn on and off the devices. The power button will be connected to the RPI's GPIO pins to properly shutdown or wakeup the device.
  5. This device will have many things tuned to lower the noise floor. This will be important if you are going to connect an I2S or USB dac to this device In such cases it is important to turn off onboard wireless and bluetooth.
What you need
  1. Any raspberry PI. Preferrably model 3 and above
  2. A new micro sd card. It should be minimum class 10. Class 10 is a sd card that can atleast of doing IO rate of 10 megabytes per second (80 mega bits per second). You will also require a card reader to burn the image.
  3. Any spare remote that you have lying around (TV, CD, apple, etc)
  4. An IR sensore like HX1838 VS1838 NEC Infrared IR Wireless Remote sensor. You can get it for Rs 32 at robu.in
  5. A LCD display. I'm using LCD display gifted by Chander. It is 7.9" from waveshare. You can get any HDMI based display that works with RPI. Check evelta.com for different models.
  6. A two way power button with led. It should have six terminals at the back. We require two way because we want both startup and shutdown. Here is how this looks like this.
Many of us have a raspberry pi or two lying in the junk pile. Some of us purchased it to get into the spirit of DIY, IOT and lot of buzzwords that gets thrown around and people get carried away. Many of us in this forum got into using Raspberry PI or other SBC (Single Board Computers) because it can be a fun thing transforming these nifty devices to coax them to dish out some music. Using RPIs to play or stream music isn't difficult. It is a child's play provided you are familiar with UNIX operating system. Who runs UNIX Operating Systems? Well almost most data centers, giants like Yahoo, Netflix, google. The macbooks runs a UNIX OS known as OSX (or Darwin). The raspberry PI's official distributed OS is also a UNIX OS - Debian Linux. Playstation uses a UNIX OS based on FreeBSD. There are many varieties of UNIX based OS. Linux is just one of them. With Linux too there has been a prolification of OS distribution - Debian, Ubuntu, Fedora, OpenSUSE, Mandriva, Mint Linux, Kali Linux. My favourite is Fedora because it is a rolling release. A rolling release is always bleeding edge and you get the latest and newest things in life. Arch Linux, and openSUSE Tumbleweed are two other distribution where are rolling releases and using either of them will also get you the latest happening in the Linux world.
I mentioned earlier that it is child's play using these devices. But the problem most people face is that they have never used Linux before. Even macbook users (mostly) don't know that most commands that work on Raspberry PI will work in their macbooks. Probably they have never used the terminal program or used online documentation known as Man Pages.
So without wasting time, let us first talk about installing the OS. Raspberry PI devices are made by Raspberry PI Foundation in association with Broadcom. They have dedicated engineers working on this. Apart from this there is a big pool of volunteers who work on this. The good thing is the kernel is mainlined. So the best choice of OS is always the official OS from Raspberry PI foundation. Let us download the OS from here
I see many users here referring to third party images from Volumio, Moode, Dietpi as Operating Systems for RPI. In reality these are official Raspberry PI debian OS bundled with many tools to configure the OS using a web browser. The problem with this approach is it takes time to develop and test. By the time these distributions are rolled out, the Raspberry PI image rolled out in this image is now an old image missing many updates. They however do serve a purpose. They make Raspberry PIs accessible to many who don't have the time or the fire in the belly to try out something new. Once you have downloaded the image from the above link, we need to burn it using any imaging software. It totally depends on which OS you are currently using. I will list for 3 type of users. Windows, Mac OS and Linux. I'm going to simplify a lot because it takes lot of effort to write. If you don't understand please ask. It will be easier to teach and learn that way. You need to put your micro sd card in a card reader and connect the card reader to your computer. Some card readers are usb based. Some computers come with a built in card reader.
Windows
Download any image burning software. Balena Etcher, Rufus and many others. You can also use the official imager from Raspberry PI. It is available for Windows, Mac and Linux. Follow this url https://www.raspberrypi.com/news/raspberry-pi-imager-imaging-utility/
Once you have downloaded and installed, you just need to run the program and follow onscreen instructions.
Linux and MacOS
You can download the raspberry PI imager from the link posted for windows. That is is the easy way if you are not familiar with Unix.
For those really want to know how to write data from one device to another, it is through a program known as dd. dd stands for disk to disk. All it requires is the input device and the output device and it will copy data from the input device to the output device. You can also give things like block size and a some kind of progress indicator.
In our case the input disk is the raspberry image that we downloaded. Let us assume that you downloaded this in /home/mbhangui/Downloads (linux) or /Users/mbhangui/Downloads (MacOS). We now need to run the terminal program. In the terminal program you run the below commands. I'm showing the terminal prompt as '$'. In your case the prompt displayed could be different.
Linux
Run the command fdisk -l to list all disks connected to your computer. Look for a disk which has /dev/mmcblk0 or /dev/mmcblk1. Some card readers will give you a device like /dev/sdb, /dev/sdc, etc.
$ fdisk -l
The above command will print all disks. You can first run the above program without any SD card attached to your computer. Then run the above command with the SD card attached. The new device will be your SD card device. Let's say this is /dev/mmcblk0. So this is what we need to do to burn the image
$ cd /home/mbhangui/Downloads
$ unxz -c 2023-12-05-raspios-bookworm-arm64.img.xz | dd of=/dev/mmcblk0 bs=4M conv=fsync status=progress
$ sync
MacOS
Here we need to run diskutil command instead of fdisk
$ diskutil list
Let's say the device for your sd card was found as /dev/disk2. Then we just need to use /dev/rdisk2. If your new device is /dev/disk3, then we need to use /dev/rdisk3. We use the 'r' prefix to access the raw device.
$ cd /Users/mbhangui/Downloads
$ unxz -c 2023-12-05-raspios-bookworm-arm64.img.xz | dd of=/dev/rdisk2 bs=4m conv=fsync status=progress
$ sync
In both the cases (Linux and MacOS) the second command is unxz -c ... | dd of=. unxz is a program that can compress or decompress. When we use the -c option it uncompresses the raspberry pi image to the standard output. In the unix world all programs get a standard input which is your keyboard, standard output which is your display and standard error which is also your display. In unix you can build a chain where one command does it's special thing and passes on finished output to another command. This is every different than Windows where you write a big application which does everything. Unix is like a super hospital where you have doctors highly specialized in their fields. Any treatment might require a team of doctors to fix the patient. A windows hospital in contrast will be a hospital having one doctor who is a pathologist, gynecologists, surgeon, psychiatrist, radiologist all rolled into one. In the above case unxz program uncompresses the raspberrypi image to standard out (which is your display). The Pipe | symbol in unix redirects the input to the program on the right side of the pipe. In this case it is the dd program. So, in effect, we have redirected uncompressed image to the dd program which writes to the device specified by of=.
Now some pictures of my build. The case was donated by @KiranPS . The case is awesome. I was lucky he discarded this case for another display with better aspect ratio. So now this wonderful case is mine. The waveshare display was donated by @chander. This is a 400x1280 resolution (extremely strange resolution where width is smaller than height). This causes issue for many apps which require minimum of 600 as the height. But for my case where I use cantata as the main gui, this is not an issue. We will talk about setup in the next post.
Front side of the streamer with 400x1280 waveshare display
Top view
Rear view
HX1838 VS1838 NEC Infrared IR Remote Control Sensor
IR sensor inserted inside the case from the bottom
IR sensor in action
The steamer in action, booting up, using the gui to play and control music. The song information comes like a blurb on all my devices and my laptops. So whatever computer is switched on in the house it will tell you the music that is being played in the house (you can call me crazy).
Wow. This is super @mbhangui.
The life that you had given to my 'almost-dead' USBridge is working like a charm. I am sure this thread is going to be very helpful to many. Looking forward.
We are going to refer to this image for wiring the Raspberry PI for remote control and Power On/Off switch.
Pin 1 is the first pin, Pin 2 the second and Pin 40 the last.
So hang on till I make my next post which hopefully will be soon.
Part 2 Setting up image for Headless installation and writing the image
The raspberry Pi image which we talked about in the first post can be used for setting up the username, password, wifi SSID and password, wifi country and the timezone. All you need to do is install the RPI imager on your laptop or desktop and run it. Below is the full installation video. Wriing the image takes around 10 mins and verification takes another 5-6 minutes. The videos are below
Configuring the image to be written to the SD card
Here we demonstrate setting up user, wifi, timezone and enabling ssh service. Once the image is written the SD card can be removed and inserted in a raspberry. The raspberry PI should boot with an IP address. Once the bootup is completed you can login to the raspberry PI to setup software and additional configuration to make it a full fledged streamer that can play your local music files on the SD card or any NAS drive. I will make few more videos for the additional setup. Watch out for new posts in this page.
Write progress for image write on the SD card
Verification Progress
Final Step - Completion
Now you just need to remove the SD card and insert it into a Raspberry PI and power it up. It should boot up without any issue, resize the filesystem and connect to the internet using the wifi settings that you configured.
Let me know how this step goes. Next I will make a video on how to connect a power button and IR sensor. Or make two separate videos. Problem is I'm figuring out how to make videos. So this might take some time
I had a doubt. If we are able to install something like lineage (android) on the raspberry pi(There indeed exits a rom for it) , could we stream Apple lossless? Wouldn't that be much better?
Yes, if it is android 14 or above. Howerver you will require minimum RPI4. Android sucks when it comes to efficiency and so you require a better hardware than RPI3. I have tried RPI3 B+ where it is extremely sluggish. RPI4 is usable.
Ubuntu Linux.... shair port sync will run apple lossless?
I shall try this! Have a few RPIs lying around.
I have attempted this with a waveshare 7inch touchscreen. Touch is not working. Do we need to run any script for enabling it. Thx. @mbhangui
If you are using the standard offiicial Linux (raspbian), for any touch screen nothing is required other than the usb connectivity between the screen and the computer (in your case the RPI is the computer).
Unfortunately Touch is not working for me. I am using standard official raspbian on waveshare 7inch with HDMI,microusb connected to Rpi4
How to configure it for LMS playback, is there any video. Thx
There are two ways.
1. One is to install it in Raspbian. Advantage is that you will always be on the latest kernel and OS. Other advantage is that you can do lot of experiments by installing full range of debian packages. Use this if you want to be on top of everything. I use this.
2. Install piCoreplayer. The advantage is that everything will be kind of preconfigured. Disadvantage is that the OS will always be few releases behind the official debian OS. I used this once and went back when I saw that they were on 32 bit OS of raspbian and many versions behind. This problem happens with all distributions (volumio, dietpi, moode). However moode is the fastest distro to adapt to the official releases. Install picoreplayer if you are a noob or have too many other important things to do than playing with linux and RPI.
An easy guid is here. It gives you steps for both the above 2 methods
First step is to get the lms server installed. This needs to be installed on just one device. This will act as the music server
Second step is to get squeezelite player installed on all devices from which you want to play music. This devices must be connected to a DAC or must have an onboard dac. This device can be RPI, macbook, windooze laptop, etc
I have already tried Volumio,PCP,Moode. Currently on Gentooplayer on main streaming RPI4 server. This is a secondary install on standby RPI4 just for visual and album art display. Is there a way to mirror the now playing track from one Rpi4 to the secondary one. Thx
That is exactly what my streaming setup does. All players display the same playing now, same album art for my local music playback which is served by RPI4 NFS server. You just have to use mpd and any mpd client. I use cantata on linux, macbook, macmini and raspberry PIs.
I have configured mpd on one of my RPI4 as the master server. All other machines in my house has mpd configured as a satellite player.
Bonus is my tv is connected to one Linux server that visualizes the music from the RPI streamer
There are two ways.
could you please advise any recomended player under Debian or Ubuntu to consider. I like foobar2000 but OS portion is the challenge being with Windows....
The best client I have found so far is cantata. It was originally written by Craig Drummond who is now a developer in the LMS project. Cantata works with mpd which is probably the best software to stream music to any ALSA device. mpd is just a music server without any ui. one just needs to send it commands to play music. You can even use mpd with telnet to port 6600. There are many mpd clients for linux, windows, raspberry pi, android, IOS. If you install mpd, you can control playback from any device (android, ios, linux, windows, mac, etc). Below is a screenshot of cantata. I'm maintaining cantata and have builds for debian, ubuntu, openSUSE, Fedora. You can install it from my apt repository at
The source code for my cantata fork is at
You will also have to install mpd by doing
sudo apt-get update && sudo apt install mpd
Once you have installed mpd, you need to edit /etc/mpd.conf and add your dac and location of your music directory. If you need help you can ask here how to configure mpd. Cantata is easy to use. mpd configuration is however more involved and requires first time setup. The full documentation for mpd is here https://www.musicpd.org/
Playback screen with albumart
Folder view for selection
Playlist view
