V-Guard Digi 200 Smart for HiFi system
I have been using a lower version rated at 3A which doesn’t even show the output. It’s been a year and no issues with my Denon. And also I used Yamaha Yht299 for 3 years with the same and it’s still working so no need to worry I guess unless you have a lot of voltage fluctuation. I thought of getting the vertex voltage stabilizer but it’s to bulky almost at the size of a 12 inch sub and weighs around 25kg so I didn’t get it.
can you confirm if denon plug fits tight in vguard socket or its loose?
