The article is confusing and in some comments misleading. Let us break down the comments
So far good. But how is the music streamer component crucial? Is it a rocket science to get data from the source to the destination using TCP/IP? Any decent streamer will achieve that without a sweat. The above statement is accurate but misleading in the sense that it picturises the job of the streamer to be extremely difficult. Now the next comment
Again, bang on. Ha Ha. dCS advocates all streamers using the same service to be the same. Maybe dCS doesn't make streamers. Now the next comment
Again no issue with the above. So almost all streamers with gigabit network interface will prove to be equal. The only issue I see is when you use wifi. The bandwidth that you get from wifi is shared with all devices connected to the wifi access point. So with a good network, your DAC buffer will always have data. At Home I can easily simulate the effect of using wifi. Go to the room that has poor wifi coverage and play some song on DSD. You will definitely get drop outs. A good software like mpd will fill the drop out with silence so that the music continues with silence.
Now the next comment is misleading and deliberate. Reviewers often abuse the use of terms like
YMMV and
garbase in, garbage out. Use those magic words to sound honest and accomodate cases which go against what you want to convey.
How will that transmission of ones and zeroes cause a problem if your DAC already has the data? Well the above statement is true only when you have a streamer with pure digital transport like SPDIF. If you are using a USB dac, all that the streamer has to do is put data in the buffer without resampling or changing the sampling rate. The clock of the streamer does not matter as most dac are now asynchronous. The DAC will use it's own clock and play data from the buffer bit perfect.
Another misleading statement to make the user go for the manufacturer's all integrated solution. Who in their right mind will connect a SOTA dac with a horrible power supply?
Another marketing bullshit below. Most DACs now, even the cheap Chinese DACs from Topping use multiple ultra-low-noise regulators providing separately to the left and right channel. This is one of the reason why these DACs achieve very low SINAD values
Another marketing bull below. It is as if the person has revealed a secret that LPS are better than SMPS. Also remember that in today's times, there are many SMPS that equal LPS on the noise front and easily outperform LPS on power delivery front.
Now after a long time reading the article, some truth again. But look at what he is saying "using an external DAC" make you achieve good quality regardless of the quality of the streamer. If Chord Electronics was making a streamer, you wouldn't have got this statement. So all good if you use Chord's DAC and any bloody streamer
Now again some marketing bull. This will hold true if you hire a 9 year old kid who has just learnt coding to write a streamer. Even a Rs 3000 Raspberry PI 3 will not do what he is alluding to below. Any normal user after reading this will be scared to try anything other than A Cyrus, Cambridge, Lumin, streamer. That is the power of the doubt that the below statement places in the mind of a clueless computer illiterate audiophile. The below can have some truth if you are using an interface like SPDIF or I2S, but it is not the universal truth. Is there any streamer out there with poor [decoding] implemenation? Zeez!!!
Rest of the article is basically all that we know and all that is needed to avoid degradation of audio quality but nothing that requires top scientists from NASA to solve the problem. Rest of the article is filled with truths, half-truths and subjective comments. I would end the thing with clocks. dCS loves to talk about the clocks. The same dCS that threatened lawsuit on one reviewer
dCS has threatened me with a "7-figure lawsuit" over my coverage of the dCS Bartok in 2021. This video discusses my response to their claims
goldensound.audio
dCS tries to hammer in your mind that clocks used by steamer are important. When using a good USB dac the clock used by the streamer has no influence on the sound unless your streamer uses a digital only output SPDIF or I2S.
USB is a superior and more "correct" interface for audio. Problem with S/PDIF is that it makes the source the "master," forcing the DAC to chase its timing. This means that if the source S/PDIF signal is not very clean, it can impact target DAC performance. Fortunately over the years S/PDIF interface has been perfected a lot and even in low cost implementation it can be excellent. You can read this excellent test done by Archimago
https://archimago.blogspot.com/2013/05/measurements-toslink-optical-audio.html?m=1
Still, there is no reason to have this antiquated architecture. Using asynchronous mode USB, the DAC can set the cadence using a high-performance clock in the dac and force the source, in this case a computer or streamer, to follow it. So the clock of the streamer will have no bearing on the quality of sound.
Yes, there is some risk of noise here as USB is a much more complicated interface than S/PDIF. Dedicated processors are used to implement it and if not isolated from the sensitive DAC analog circuit (including its clock), we can still get polluted output. Fortunately this has also been sorted out for the most part and in high performance DACs it simply is not an issue. If you still think USB is noisy then you can get this USB cleaner. It will do a far better job at cleaning than my USB Regen from Uptone that cleans nothing!!!
Rest of the article is same. Few truths with sprinkling of half-truths and subjective comments meant mostly as promotion/advertisement.
