Fostex 126 En + Eminence Beta 12 A 2 Full Range Speaker System
A small update. I have changed my drivers from 45 to 2a3. Magic happened with my existing Denon CD player and NOS Teradak. I am using my old Jamo cable not easy to get now.
Sometimes we try to upgrade chain without realising possibilities need to xplore within. May be a slight mismatch is contributing to big frustration.
As far as I experienced if you are okay with existing digital media then Single ended tube amp and high sensitivity speakers is the best combination to experience great music which each artist try to create.
For me this combination is not making me feel that I am missing turntable or Sub woofer to get punch. Even though I know TT can take this to next level.
Now this system is fully ready of someone want to experience the performance. I am waiting for Satyaki also to experience the setup as he himself have not experienced outcome.
Another update. Those who crave for Bass response. Many a times we get to convinced by music as it is and you are getting natural base and this is how is in studio.
Not always correct. Unless your amp and speakers are sink you will always cry for missing bass response. Every musician is taking care of base. Every note is having equivalent weight of bass response. Music will never be sweet of you are not getting both balancer base and trebles.
I feel lucky when I see my speakers performing well aligned with Lyrita 300b amp. If amp and speakers are well tuned then your ordinary source will also do magic.
If both components are well aligned then there is less worry of placement acoustics etc.
to feel what I am saying one need to be experience.
I am in Bangalore and someone need to have feel can DM to fix time to get experience.
This is a different league. I have gone through journey from Cardence, Dali, Dynaudio, KEF, Harbeth, Tannoy and many others.
This is entirely different. Thanks to Satyaki and Sadik once again.
Another update here. Now I have 4 nos 2a3 tubes glowing in my amp. Full DHT, AC heater, simple accessories but full body sound no lag no missing details no loose punch. Wow we did it. Thanks to Viren Bakhshi Sir! Your amp is rocking.
Very pleased to see the synergy across all the components delivering the intended emotional impact.
Thanks to you. From here it’s game of money and ego. But the way music is appearing on this system is good enough to get state of satisfaction. And I am asking myself do I need to have some different system and then answer is no.
