I have used genelec 8040b in my bedroom for 7 years ...Any idea how Genelec would sound. I hope there is a showroom in bangalore not sure if they allow audition. Any user here who prefers Genelec over B&W or other audiophile speakers ?
My uncle has 8341a.I am looking forward for 8341A since they are coaxial three way.. for a near field listening what do you think subs are necessary lets assume its a modest room 10x15? did you calibrate with glm kit ?
My room is 10x13 Ft where these speakers sit.I am looking forward for 8341A since they are coaxial three way.. for a near field listening what do you think subs are necessary lets assume its a modest room 10x15? did you calibrate with glm kit ?
Totally agree, with small bookshelf's for stereo, low end will definitely be missing due to small drivers and cabinet. A good sub is essential in such setup imo.My room is 10x13 Ft where these speakers sit.
In my experience, a subwoofer is an extremely critical part of any stereo specially with bookshelves. Please note I am NOT at all a bass head, but it will be physically extremely difficult if not impossible for a small 5-6 inch driver to dip down to 40Hz odd, where a lot of low bass in a lot of music sits (think bass guitar, keyboard/piano etc). And this is the stuff you can hear not the "feel part of things".
I also personally prefer to run Subwoofers with a cut-off around 80-90Hz instead of running them full range - I think Genelec subs have a default at 85Hz. I look at it as a third speaker - So your bookshelves are doing 80Hz+ without stressing themselves out & the sub is doing all the work below. So nothing in there is overreaching beyond their comfort zone.
Yes, so I FEEL - regardless of the size of your room, if you want to do justice to your music, a subwoofer is criticalJust in my opinion & personal experience.
8341As are a different beast, if budget is not an issue, there is no discussion there.
Below is one of the initial graphs of how these speakers behave in my room along with the sub. I could eventually tame the two peaks as well around the 45Hz & 120Hz.
Unable to find the graph before the sub, which basically had the sound drop off steeply below 70Hz.
I do not find that to be the case. What you get is a colorless sound - no real "sound signature". One of the most beautiful aspect of such speakers is, they will respond very well to EQ/DSP and also it will be easier to correct for the room issues. IJust using the DSP on the speakers & sub - I can get them to sound right in any room in my house!Is the sound of genelecs on the analytical side of things being a studio monitor?
could you elaborate, what is meant by "analytical" sound?Is the sound of genelecs on the analytical side of things being a studio monitor?
Clear and very resolving especially the highs and true to the source. Basically, it leads to analyse the music during listening. Perfect for recording, mixing and mastering. This is my understanding.could you elaborate, what is meant by "analytical" sound?
Being a high end studio monitor.. these sound absolutely fatigue free.. and have a very good frequency response.Is the sound of genelecs on the analytical side of things being a studio monitor?
Has a wider sweet spot because of being coaxial..
Thank you.Being a coaxial I assume it is good for mid-field listening, say, 6 feet away from the speakers.I do not find that to be the case. What you get is a colorless sound - no real "sound signature". One of the most beautiful aspect of such speakers is, they will respond very well to EQ/DSP and also it will be easier to correct for the room issues. IJust using the DSP on the speakers & sub - I can get them to sound right in any room in my house!
They work near field also.. even at a metre one is going to get coherent soundThank you.Being a coaxial I assume it is good for mid-field listening, say, 6 feet away from the speakers.
Subwoofer placement is crucial in your room to extract the benefit from having 1 or 2 subs..If I am going to pair W371 subs I should be able to force the W371A handle the 20–100 Hz (or so), so the 8341A can breathe freely from 100 Hz
is this a good idea and can be accomplished via crossover using the GLM kit correct or any suggestions ?
These monitors will mostly bi or tri amped internally. So, you don't benefit much from better mids from your Genelec by offloading the bass to a sub. However, adding subs always has its pros.If I am going to pair W371 subs I should be able to force the W371A handle the 20–100 Hz (or so), so the 8341A can breathe freely from 100 Hz
Genelec has a very active forum with members from the pro industry & genelec reps giving sound advice regarding placement, config, listening distance etc. They also have some comprehensive information posted on their website on a lot of topics.If I am going to pair W371 subs I should be able to force the W371A handle the 20–100 Hz (or so), so the 8341A can breathe freely from 100 Hz
