Which region-free BlueRay player to buy?
manishk13
Is there any blue ray player available in India which is region free ? Yesterday I went to Sony shop and the guy said the Rs 9990/ player to be launched (model 360 I guess) is not region free. What is the strategy you guys are adopting ? We will buy blue rays from various sources - India, US etc. So, isnt a region free blue ray player mandatory - ideally ?
Please help
Manish
You'll have to buy a blu-ray player and get a mod kit. Nothing available 'region free' off the shelf. The Oppo mod kits can be clipped on fairly easily. Other mod kits require soldering. so the path of least effort would be to get an oppo, a mod kit and then clip it on. Even less effort (but a lot more expense) would be to order a pre-modded player from ebay or one of the foreign sites.
Would appreaciate points / links from where these Mod Kits can be purchased.
Anyone Actually done this ?
You can buy that Sony Player from Sony India i.e S370 for Rs.9990 and then order a mod kit from Blu-rayMods- Home or Stegen Electronics, the mod kit comes with detailed instructions and with the help of a TV mechanic or Game console modder you can get it fixed inside the player for a complete region free operations for DVDs as well as Blu Rays.
I have personally achieved this with my Oppo BDP83 and you can find more information about it on this thread : http://www.hifivision.com/blu-ray-d...ssions-reviews-oppo-bdp83-blu-ray-player.html
THANKS to both of you for your very prompt and detailed replies.
Much appreciated.:clapping:
