region free blu ray player
nandac
yesterday i bought a sony 370 bluray player because the guy the shop claimed that it was region free. but i have my doubts. i called sony tech support and got conflicting information from them - one guy said it was multi region and another guy said it wasnt! so is it multi region or not? if not, anyway to convert it? and what are the other options for multi region blu ray players in india - philips, pioneer, panasonic etc?
for me multi region is a must because i often order stuff from us/uk which cannot be found in india.
appreciate the feedback.
By surfing a few sites, it seems you can get both region locked and region free players. The best way to find out is to play Blu-Ray discs from all three regions.
None of the Blu-Ray players come manufactured as region free for Blu-Ray. You have to get a mod kit and install it. Please be aware that mod kits are not available for many players so you have to choose your player carefully.
Sony BD player region free? EXTREMELY UNLIKELY.
Check the back panel of the player. The region code will be marked there. Sony India sells BD players for Region C only.
I suggest that you return it, if that is possible and region code is important to you.
saw an ad in what hifi june issue ----viewlab---claims to be multiregion for BDs @ 30k , chk it out
Probably the guy was referring to region free for DVD not blu ray. I have a region A BDP 360. Other options in region free are
Oppo (either Pre modded or with mod kit)
Dune - Region free for Blu Ray
Viewlab - Region free for Blu Ray (refer to most recent issue of WHF)
If we go in for Indian Blu Ray players they normally comply to Zone 'C'. It is important to note that all Indian blu ray discs are multi zone so any blu ray plyer works, but forimported blu ray discs normally the coding is 'A' so it is best to go in for a blu ray player compatible with zone 'A'
Panasonic BD 60, BD 80 & Pioneer BD 320 both are zone A coded.
Many international (genuine Hollywood) Blu-Ray discs are also region free. Here is the list of studios and their region coding practice for BDs in USA:
20th Century Fox: Region A
Disney: 50% region free, others Region A
Dreamworks: Region Free
MGM: Mostly Region A
Paramount: Region Free
Sony Pictures: Region Free
Universal: Region Free
Warner Bros: Region Free
Source: Blu-Ray Studio Region Free/Locked Coding Statistics and Movies List
If the blue ray player supports HD audio decoders (true hd and hd audio master, etc) and has analog output, then I don't need AVRs with HDMI in or the decoder requirement - Is this right ? This is assuming that my TV is full HD.
Also one question: If the Blue ray player has the decoders, taking the output via coax and connecting it to AVR that doesn't support the decoders will give me the HD audio ? As I said already, TV is Full HD.
Thats correct. However, most bd players have poor bass management so could be an area of concern.
Coax doesnt support HD audio only DD or DTS5.1
Sud98 has already answered answered this query, but I thought I will elaborate a bit, as I have seen this question being asked many times.
At the outset, it is not just a question of which part of the system can decode the audio signal. And, for audio, it really does not matter if your TV is FullHD. What matters to the TV is the video part and not the audio.
The audio can be decoded anywhere, but for it to reach the next part in the HT chain, something called bandwidth or transmission speed comes into play. Typically, Dolby Digital needs a transmission speed of about 440-640 kbps, while DTS demands 700-1.5Mbps. When we move into Dolby TrueHD and DTS HD, and DTS Master HD, the bandwidth requirements jumps to between 4 Mbps to 24 Mbps. This speed cannot be handled by either digital coaxial or by optical transmission.
Let us assume we have a DTS Master HD and I connect the player to the AVR with a optical fibre for digital transmission. What will happen? Typically all movies have a standard Dolby Digital or DTS in addition to Dolby TrueHD or DTS HD/Master HD. If you use digital coax or optical, the Dolby True or DTS HD/Master HD will be ignored and standard version transmitted.
If you opt to decode at the player, you have to connect 6 audio RCA cables for 5.1 and 8 cables for 7.1. This is assuming the player has analogue audio out. Even if a player has analogue out, the quality of sound depends upon the decoders used as well as the DAC used.
If you want to transmit Dolby TrueHD and/or DTS HD/Master Audio in digital form, the only option is HDMI.
cheers
cheers
I have an old Onkyo reciever (that does not have HDMI) and hope the Oppo is good enough to connect analog -to -analog.
If you are talking about the Oppo BD83, it is really very very good. I would always use it's decoding and DAC over any AVR other than those costing a few lakhs.
