diy
first of all you ll have to decide what u want to go for
just high sound output or high sound out put all togther with pressure and proper sound dynamics in other words this will decide the size of ur speakers
and thus the nmber of drivers and the quality per channel etc
secondly diy speakers that i would recommed you should feature the best tweeters but as per a persons personal taste the tweeters to be used can be either soft domes or metal domes
soft domes sound more smooth and detailed
some prefer aluminium or metal domes just because they prefer a metallic sound quality or a very high clarity at lower volumes but these can somtimes sound harsh and cause fatigue to CERTAIN listners at higher volumes
and same is the case with selecting other drivers i mean mids and woofers
plz let me know what speakers have you auditioned and do you like the polks and also what kind of av reciever and other dsp's or amps you have
thanx
aminder
SPEAKERS
Custom built speakers
FRONTS : feature twin front and back firing neodium ring radiator tweeters from sb
acoustics and kevalar hand woven cone mids from peerless denmark in MTM configuration
plus non pressed paper cone woofers
CENTER: featureS twin ring radiators( centre offset) and kevlar mids in mtm
configuration
SURROUNDS: similar tweeters and mids in Dipole/Bipole diffusing setup
FRONT HEIGHTS / BACK HEIGHTS : similar drivers in bookshelf directional straight
firing setup
SUBWOOFER 1: YAMAHA YST 315
SUBWOOFER 2: 2 CUSTOM BUILT SUBS BASED ON A POPULAR OLD HSU DESIGN THESE BEASTS PLAY
AT 18HZ
TACTILE TRASDUCERS:
BUTTKICKER LFE KITS POWERED BY BUTTKICKER AMP
AURA BASS SHAKERS X 2
AV RECIEVERS:
yamaha rx-v3900 (FOR FR,FL,C,SL,SR,FR HEIGHT, FL HEIGHT)
Yamaha rx-v1600 ( FOR PROCESSING AMD POWERING REAR HEIGHTS BOTH L AND R)
Yamaha rx-v800 ( FOR POWERING CUSTOM SUBS AND AURA BASS SHAKERS)
MISC PROCESSORS
Velodyne sms-1 BASS MANAGER FOR ALL THE SUBS
YAMAHA 10 + 10 BAND GRAPHIC EQ FOR MUSIC
REKHORN F1 FOR AURA BASS SHAKERS
REKHORN B2 FOR CUSTOM SUBS
VIDEO PROCESSORS:
Dvdo edge ABT video processor
Cyp instant HQV realta VIDEO PROCESSOR
BOTH OF THESE PROCESSORS WORK AT THE SAME TIME AND DO WHAT EACH OF THEM DOES BEST
DVDO FOR UPSCALING AND multi-directional diagonal filtering
HQV REALTA FOR 4D per pixel motion adaptive noise reduction AND AWSOME PICTURE
PROCESSING(COLOR MANAGMENT ETC)
PLAYERS:
Popcorn Hour C-200 MEDIA PLAYER
Samsung bluray bdp-1500
Toshiba HD E1 HDDVD
SAMSUNG DVD PLAYER
Custom HTPC IN A COOLER MASTER CABINET
POWER MANAGEMENT:
APC power conditioner/backup
PROJECTION EQUIPMENT:
Panoview motorized screen 16:9 WIDESCREEN MATTE WHITE
Panasonic ax200 projector
REMOTE CONTROL SYSTEM
Philips pronto tsu9400
Philips rfx9400 WIFI FOR PRONTO
IR DISTRIBUTION KIT
LIGHTING
Lutron dimmer
Luminance mood lighting(CAN DO 64K SHADES)
CRABTREE AURA IWS
TV:
lg 42in lcd
MISC:
SONY 7IN LCD MONITOR FOR SETUP USED WITH VELODYNE AND YAMAHA AV RECIEVERS
COOLER MASTER COOLING EQUIPMENT FOR AV CABINET COOLING
