spirovious
Hi friends,
We talk more about xonars & not much about Onkyo.
If you check,these soundcards are since long in market(2006).Still not much reviews.Even in our forum,no one has it (I suppose).If you see specifications,it has Wolfson WM8740 DAC,9.1 analoge out(stereo +7..1),made in Japan.Layout shows Large capacitors.
Onkyo Wavio Soundcard SE-200PCI
Onkyo Wavio SE-200PCI LTD Edition
Signal-noise ratio: 115dB?2CH ANALOG OUT?
Frequency characteristic: 0.3Hz?88kHz?2CH ANALOG OUT,?0/?3dB ?
Digital IN sampling frequency: 32, 44.1, 48, 88.2, 96kHz
Digital OUT sampling frequency: 32, 44.1, 48, 88.2, 96, 176.4, 192kHz
Hardware requirement:
Corresponding type PCI (the Ver. 2.1 or more) the PC/AT compatible machine which has the bus slot
OS: WindowsR2000 professional (SP3 a ve), XP (SP1 a ve), Vista (None of them corresponds to 64bit edition); System manager authority (Administrator) with only it is enabled
Processor: 32 bits (x86) or 64 bits (x64) processor; Above 800MHz (2000/XP), above 1GHz (Vista)
Memory: Above 128MB (2000/XP), above 1GB (Vista)
In addition: CD-ROM drive (necessity at time of software installation)
Input:
ANALOG IN x 2 (stereo RCA, internal connection)
MIC IN x 1 (? 3.5mm/monaural)
DIGITAL IN x 1 (light)
Output:
2ch ANALOG OUT x 1 (stereo RCA)
DIGITAL OUT x 1 (light)
7.1ch ANALOG OUT (Front L/R, Center, Surround L/R, Surround Back L/R and Subwoofer)
Dimensions: (mm) 22 (w) x 121 (h) x 163 (d)
Weight: 200g
SE-90Pci
Price around 15k
Onkyo Wavio Soundcard SE-200PCI LTD Pro PCI Sound Card! - eBay (item 220632549847 end time Oct-02-10 23:49:06 PDT)
Onkyo Wavio SE-90 PCI - low profile
So any one knows them?
Few online reviews-
A simple review of Onkyo SE200 Soundcard - Head-Fi.org Community
New onkyo Soundcard - Storage Forums
Google Translate
Google Translate
USB soundcard-
Onkyo Wavio e-shop - Onkyo Wavio SE-U55SX external USB sound card
Onkyo Lays Claim to the Worlds Best USB Soundcard Title
Input:
Output:
Weight: 200g
SE-90Pci
Price around 15k
Few online reviews-
Google Translate
Google Translate
USB soundcard-
