vasishta.sushant
I just bought this electronic clampmeter, primarily to test how much power each component at my home is consuming. Since I am little too finicky about my monthly power bills, wanted to optimize my usage based on the power usage.
Basically I simply noted the voltage and ampere ratings at the AC main, for the various appliances/combination of appliances. Kindly do note that the meter I bought might not be dead perfect with its findings but nonetheless it gave a good picture of the power consumption pattern at my home.
I tested the following things primarily:
1) LG 32" HDTV
2) My PC (Phenom II 925, 4GB RAM, ATI 5770, APC 550VA UPS and other sundry hardware)
3) PS3 500GB (latest 25xxx version)
4) Onkyo 3300 HT System
5) Airtel IPTV Settop box
I'll simply put my findings (only Amp rating. Multiply with 220 to get the actual wattage), as I noted them:
PC+TV+AVR
Idle PC Usage : 1.1
Music Playback on foobar (low to medium volume/high volume): 1.2/1.5
Movies: 1.2 (little strange. I was hoping more)
Gaming(Cutscenes/Main): 1.5/1.9
PS3+TV+AVR
Music: 1.1
Gaming (didnt check)
PS3+AVR (with TV turned off)
Music: 0.6
Only AVR
(Music with netbook running on battery): 0.2
Only TV (with IPTV Settop box)
0.5
Some strange observations:
* Turning off all the channels other the main fronts does not have any effect on the power consumption of the HT system. Earlier I used to turn off the center/sub/rears, thinking that it will save some energy, while listening to the music. I guess the AVR takes care of this automatically.
* UPS itself is extracting like 0.1. This is strange since this equates to nearly 22W power consumption, even when nothing is connected to the UPS (in my case the PC and PS3 are connected to the UPS and the rating was noted when both were on standby/turned off mode).
This was it.
Helped me a lot since I can listen to the music now without the worries of hefty power bills at the month end. My AVR is rated at 350W which made me use it as less as possible (miser me
). At least now I do not have that tension on my mind.
If you guys want me to check any other parameters as well, let me know.
1) LG 32" HDTV
PC+TV+AVR
Idle PC Usage : 1.1
PS3+TV+AVR
Music: 1.1
Music: 0.6
Only AVR
0.5
This was it.
