ShaQ.Blogs
That statement was explicit not to undermine you...but your advice. To make it explicitly clear to anyone who is reading this post, that this is not the way to go and to ignore that post. That advice is a last ditch effort to set things work right, after making not so great choices!!You know what? Learn to talk to ppl first of all and save your knowledge for yourself.! Thank you.!
When a newbie or someone who dosen't know how some of the stuff works (Understandably you cant expect everyone to know), comes over and asks for advice, he is expecting reliable advice. Whatever he gets here he might think its right and spend precious time on it breaking his head. Other people who also read or bump across such posts will also think this is reliable advice. Makes it worse, especially when you consider that he is getting this kind of advice from someone who is kind of in the business (unfortunately), which tends to make people think, oh he knows!
With that one statement, one can understand that you don't in fact, but only bits and pieces...which is not good! So in this case, its best when someone with half knowledge, keeps that half knowledge to himself, and let someone else with better knowledge advise or... just let it be. He will go in search of other sources if he doesn't get help here... which hopefully can be reliable.
Statements like this are applicable for the speakers with bass limitations because, the user, unfortunately has no other choice and he if forced to go this route. The +20 Hz is used when the bass limitation is high. It is when your FS cant play low bass only then, do you set your cross over based on your FS. Most good FS's nowadays will easily play low bass even upto 30-40 Hz...some even lower. Good initial choices of speakers (with good low bass) makes life great, and hence can avoid distortion and early clipping by NOT setting bass too low. This of course requires reliable advise on choice of speakers. While choosing speakers, 'bass crossover' should be highly considered as this can dictate many other options including which receivers to drive with (and yes...choose your Fronts first and then the receiver).Crossover should be 20hz + your minimum floorstand frequency.
When the FS are capable of playing low bass, then life is different & wonderful. This dosen't mean that you have to make the FS to play bass....you can do it, and there are many who do it. But, there are better choices with really really good reasons why you should go 'the better route'. Eventually it is all about allowing your speakers to play freely (Unless a little more distortion & clipping is acceptable at louder volumes). You want more bass...get a second one and place it well!
