how to mount sony bravia lcd tv on a wall ?
supu
India
i just bought KLV-40BX400 from grey market so i want to know that how to mount it on a wall ?
Get a wall mount bracket from a electronics shop stating the size of your LCD. DOnt know for how much it sells in your locality. It must be less than 1000 ruppees i guess..
The wall mount bracket consists of a wall stand and two clamps which has to be fastened to your TV. The stand has to be fixed to the wall with the help of nuts and related items supplied along with the bracket. Now the TV can be hooked to the stand. Simple as that. You can even call an electrician to do this job. When hooking the LCD to the bracket i suggest you to have one more person on the other side since holding the TV with both your hands and doing it yourself is not a good idea as the 40" one isnt weightless...
There are two types of stands, tiltable and non-tiltable. Better go for the tiltable one as you can adjust the position of the TV in case if you find it difficult to connect cables at the rear of the TV.
U can pick up the mount from national market itself, it will cost u rs 500. Which store did u pick up ur tv and how much did it cost u ? I recently picked up a sony BX420 40inches from manish in sukh sagar market i paid 38k it plays all the video formats through usb :)
i bought it for 37k from surat. is there any video that shows how to mount sony lcd ?
Supu, you don't need a video show. It is very simple. Wall mounts come with two parts - One is a back plate that you mount on the wall, and the other is a face plate that your screw on to the back of the TV using screws that will come with the wall mount.
1. Separate the two parts and screw the face plate onto the back of the TV.
2. The back plate will have four or more holes. Holding it against the wall where you want the TV, mark the wall through the holes using a pencil. Drill holes in those points using a appropriate drill bit, and insert plastic wall plugs (mostly included) into the holes on the wall. Now, using a screw driver or a wrench, mount the back plate on the wall.
3. Now simply mount the TV onto the back plate using the hinge at the top that will have an appropriate wedge on the face plate.
No no. Dont use those plastic wall plugs. They might get loose and come out in the course of time. Use wooden pieces for this purpose. Those plastic plugs are for light uses only. Its safe to use the wooden pieces because the back plate has to hold the LCD which is not that lightweight as you think. If its a 22 or 27" TV it doesnt matter i think. My electrician did this job for me and he stated that these plastic plugs are not advisable for heavy usage...
No no. Dont use those plastic wall plugs. They might get loose and come out in the course of time. Use wooden pieces for this purpose. My electrician did this job for me and he stated that these plastic plugs are not advisable for heavy usage...
I can only smile at the old fashioned ideas that the electrician tells you and that you believe in.
Wood tends to rot and lose it's grip. In time, you can just pull it out with your hand. Even if you use something like teak, as you insert a screw, you are splitting the wooden plug into multiple pieces that can easily slip. I have used plastic wall plugs all over my house and they have been there for over 14 years now without issues.
A wooden plug is easy for electricians and others as it does not need accuracy. If the screw does not fit properly, you can simply reposition the the screw, or hammer it in at an angle. With plastic wall plugs, you have to mark the walls accurately. You cannot turn the screw in sideways, and you do not have more a few mm as leeway. A wooden screw is also the only option for electricians who do not use electric drills to create accurate holes in the wall.
A plastic wall plug will never rot. In addition, as you turn the screw in, the plug actually expands inside and grips the sides of the hole in the wall. If you are very particular, you can actually paste a little amount of glue such as Fevicol on the plug before you insert it into the wall.
If you are uncomfortable with plastic, you can also use metal plugs that are available today and that come with the right size bolt.
I would like to add that there are different types of plastic plugs. You need to use the ones that have wing like anchors on the sides. Once you put in the screws, the wing anchors expand inside the hole and they will never fall out, unless your wall itself is made of soft material (such as mud bricks).
You can use these type of plugs:
DO NOT use these plugs - they don't have any anchor:
Wooden plugs tend to fit tightly because of the property of wood to tighten itself around a nail/screw, but again there is no anchor in the wooden plug and if the quality of the wooden plug is bad, then it will disintegrate. I would agree with venkatcr - they are used by old electricians who have still not come to terms with using modern instruments (a drill, a tape measure and plastic plugs).
Guys,
I am getting nervous just reading the posts on how to attach the wall mount. You should be using concrete anchors with lag bolts such as in the pic below that will hold atleast twice the weight of the TV (just to be safe).
To the OP. It sounds you are doing this for the first time. Get a good mason or carpenter to do this.
You can buy these very cheap in any hardware store.
I don't recommend normal wall plugs to hold TVs and I have installed quite a few in the past few years.
A friend of mine purchased his Sony Bravia in Singapore. He faced the same issue of wall mounting.
He went to Sony World showrooms. Those guys said that they will fit it only for a fee as the TV was sold from their showroom. Fair enough. They said that the cost of wall mount would be Rs. 2500/. Fitting charges, Rs. 1500. My friend told them that he will get back (a nice way of saying "take a hike").
He contacted Sony and they guided him to the service center in Pune. The wall mount was sold for Rs. 900. For fitting, he contacted a carpenter who did the job for Rs. 400. But carpenters are very reluctant to take up odd jobs like these.
Guys,
Are concrete anchors with lags the type they use to put additional brackets in the ceiling (for ceiling fan)?
I've wall mounted book shelves and file cabinets using plastic plugs. They must be >50kg loaded and after several years, there is no sign of any displacement.
This article:
My Electronic Review.com-Install TV on a brick or concrete wall
indicates a plastic anchor can hold >100kg in brick or concrete
A #8 plastic anchor in [...] brick or concrete it will hold 325 lbs. If you are like me and want to make doubly sure, you can add some adhesive to the anchor when you insert it.
Guys,
Completely agree. The bolts for TV brackets are slightly bigger, i think 3 inches long and 5mm wide. Please do not use normal screws.
