BD Player with 7.1 analogue output
sunilyo
New Delhi
Please advise me a BD player which has 7.1 analogue output as i will connect it with the 7.1 input on my Marantz SR-4600.
something link the Panasonic DMP-BD85 (but this one only 5.1 analogue output)
Samsung 6900, oppo bd83/93/95, Cambridge audio azur 650bd,- some which I know have analogue out. Also I guess Sony 570, not sure though cos it's not listed for india.
Also has onida bdx 1110 5.1 analog outs. I have the onida bdx1110 with me but still using digit out. Not tested the analog outs.
pandu
when u want 7.1 out, check does the player supports- dts-hd ma and true hd codec, and also can it be updated via internet in india, becoz as dvd era is getting over and bluray era has started. remember bluray is still at infant stage,it may get lot of features soon be added, iam expecting more audio formats to be added...we need to have update feature for it..
@all thank you everyone for your responses and suggestion.
@drkavint I think all BD players do decode DTS-MA and DD-THD, isn't it? Also will look for the update feature. BTW do you have any suggestion for a BDP with the update feature?
@baijuxaviour How is the quality of your Sherwood BDP and how much did it cost you?
i procured a panasonic DMP BD80 bluray player from amazon in november 2009 for 7000 rupees which has an analogue 7.1 out which can decode DD HD & DTS Master Audio to my old Denon 1507.
@Audiodoc thank you for your reply. Could you tell me how u have connected it to your Denon (digital or analogue) and what settings are your using on your BDP (bitstream or PCM).
This is what i want to know as i think this is the only solution for me.
I bought the sherwood bdp from a member for 8k. Picture quality is very good. It can decode hd audio. Stereo channels are not converted to 7.1/5.1 through the analog output.
While BD players will be there with multi channel analog outputs, it will be usually better to use the AVR and use HDMI connection.
The blue ray player has 8 analogue outputs on the back which I connected using four AV cables. You cannot bitstream since my receiver does not decode DTS HD Master Audio of DD HD.
Its data is sent as analogue only and the quality difference is perceptible even through the Logitech Z5500 let alone the Denon Wharfedale Combo. I am planning a new receiver which will do the decoding however this BDP will futureproof the older system for a second room.
iam using samsung bdc6900...got all features,updatable, internet+7.1 analogue out (but iam using hdmi)
