What's a good free audio cd burning software?
I have found that many times when I burn CDs from flac (using Nero),there is some quality loss.Do dbpoweramp/Burrrn can burn close to original cds?
The DB and EAC burn to near lossless quality, although i dont know or have any methods to follow the quality of rips :)
I have done apple to apple comparison with EAC converted audio cd , and you cannot found any difference while listening on .
EAC recommended :)
Both DBP and EAC burn exactly what is fed to them! They neither add to nor subtract from the original bitstream! They are extremely reliable tools.Some ways to check this is to enable Accurate Rip and compare rip checksums with other people's checksums stored on the Accurate db; another way is to burn using EAC or DBP with the correct write offset and rip the track back to hd using the correct read offset and then compare the original and newly ripped files. Altogether, too much work for too little 'bit' gain! I have ripped with read offsets and without read offsets and I have not found any difference, even after listening to close to 200 albums. Instead, spend the time listening to albums! :)
