Strange for me as my Samsung 40D5500RR LED TV is Full HD, donno why this is happening.....
Anyways now I have almost fixed this and for another 5% issue I will keep doing R&D to see if I ll be able to fix this issue![]()
As you had mentioned that the resolution was 1600x1200 in xbmc try changing now to the original one with your TV 1920x1080p and see the result as the snow dots have disappeared.
Also try official Xbmc eden 11.0 instead of the patched hd version.
It will work. But try one of the latest nightly build. It has built-in hd audio decoder. I am using nightly as on july 1st and it works fine.
Index of /nightlies/win32
now all concentration on understanding / configuring XBMC
Don't know when i ll start watching movies movies like beforehyeah: as now days only busy with throubleshooting or tuning
hyeah:
This is the fun part of assembling HTPC. Everyday you learn a new thing or two.
I think we need a dedicated XBMC setup thread in HFV :licklips:
Baiju you are using that since longtime why don't you start that, it will help ushyeah:
thanks
YP
