soviet_selva
Designing a ported sub without knowing its T/S parameter is like fitting the speaker in any random enclosure. Ported are more sensitive to proper designing. Sealed design are forgiving. Proper tuning of the port, volume of the enclosure is very important for ported sub.
Which Order of crossover did you use? Try using quality inductance and capacitance, something like this DIAMOND 2 WAY STEREO PASSIVE SUBWOOFER CROSSOVER S @NEW | eBay
I agree with you, After reading some posts where some DIYers tried ported type bookshelf speakers and were disappointed with the port noise so then i decided to go with the plain sealed enclosure type cabinet.
After suggestion from Jaudere i e-mailed to IWAI and yes, got response from them they do sell speakers, it was a Good news for me. Thank you Jaudere for letting me know this.
There quote for 8" 4ohm sub woofer was Rs 1165 per pc (+ Excise, CST & Freight) and for 8" 8 ohm sub woofer was Rs 705 per pc (+ Excise, CST & Freight). the link to 8ohm model Iwai Electronics Pvt. Ltd.
mostly will buy this after 3 months or so
