Wanted to know the difference between Coaxial and RCA for interconnects ?
Thanks ,
So in other words a coax should do a similar job with the added advantage of better sheilding ?
Can I use Coax to connect my power amp to my processor and expect the same results as I would with using RCA (Price being same 2k - 3k)
No. That is not true. RCA is a just a socket type and not an interface. Interfaces are like coaxial, component, composite, etc. All of them use RCA plugs. One can very well use a simple RCA cable to connect coaxial terminals. Question of quality is there but that is a different topic.Some more differences:
1) Coaxial can transfer signals up to DD/DTS for HTS. Assuming by RCA interconnects you mean White and Red RCA interconnects it can transfer signals up to stereo.
2) However with the RCA interconnects you can use 5 cables to transfer DD/DTS signals.
Vinod
Thanks ,
Interface is different while connector is different.My bad. Can you point out where I am wrong here?
There are many types of interfaces such as Composite AV, Composite Audio, Component Video, SCART, S-Video, Optical/toslink, Coaxial Digital, HDMI, USB, etc. Interfaces determine how audio and video signals are carried from source to destination.
From best to worst ....So out these which one carries the signal better/best.
Video: HDMI Component S-video Composite
Audio: HDMI Coaxial/optical Composite
Sent from my GT-I9100G using Tapatalk 2
For stereo audio,
the following is debateable
HDMI has a really lousy for stereo audio. HDMI derives the audio clock from the video clock which is 74.25MHz. So it needs a PLL to generate the audio clock - this basically means you get horrible jitter. More info in Charles Hansen's post here:
HDMI has the highest jitter of any interface - Charles Hansen - Computer Audio Asylum
"Coaxial" is a type of cable construction. RCA is a connector type, meant for terminating unbalanced signals. So the question posed by the OP is unclear.
An RCA connector could be used to terminate a coaxial cable.
"Coaxial" is essentially unbalanced cable type. It has different characteristic impedance - typically 50 Ohms and 75 Ohms - depending on intended application.
