DarkKnight
Hi everyone,
I have a Htpc (xbmc) and i use files from my laptop or main computer to play. I have read that if all the computers are on the same LAN the files playback is not dependent on the internet bandwidth. I have this setup
https://www.dropbox.com/s/irwgfp84wqbj2a9/Capture.PNG
I have read in some guides that if you want to setup Lan network sharing instead of obtain ip adress automatically option
I used that method and gave the ip adress listed by my router. It worked last night but then stopped after I checked the properties. :S i also got DHCP not enabled error whenever I manually enter the ip.
Can you guys tell me where I'm going wrong ?
