The Giveaway Thread
The BPL Worldspace Receivers are still available for FREE!
Also giving away a very interesting product - Creative Audigy 2 ZS Notebook (PCMCIA Sound Card for Laptops). I haven't used it in ages but it works. It is 7.1 Channel, 24-bit, 192 Khz, DVD-Audio Capable sound card. Comes with a soft plastic case, the cable adapter for 7.1 channel output, Driver CD, a DVD-Audio sampler.
Pictures:
Is it still available , sir?
I found an unused Thorens TD150 belt while clearing out some stuff. This belt was bought in the early 80's as a spare and never used . It looks to be in good condition and is still pliant . The belt if I am not mistaken will fit the TD160/145 Thorens TT's also.
My TD150 is long gone. Anyone who wants the belt can have it.
Rajiv
Rajiv
Super Rajiv. I'mm timing this one. I reckon this will be gone in minutes.
I only wish I owned a Thorens :)
Cheers...
I have a Reliance Modem Netconnect ZTE MG880 to give away. Anyone interested?
The connection is long gone and not in use. Anyone is welcome to pick it up. First come first serve.
It comes with the modem, the headphone and a mini CD in its box.
Vinod
I have an Airtel HD (Multiroom) setup for a give away in bangalore. If any one wants and are willing to transfer it on their name , PM me. No dues on the connection and I switched to Tatasky+ hd long back , these are lying idle.
Dear All,
I have the following PC components for giveaway:
1. Diamond Viper HD2400 PRO 512MB AGP GDDR2 Video Card - bought it in 2008 through Amazon.com
2. P4 motherboard (865 probably) - this does not have onboard LAN - supports the above card
3. LAN card
The above with a P4 CPU + RAM + Cabinet + Sata HD can be easily converted to a HTPC - capable of 1080p videos with ease
Thanks and Regards
Anshul Kwatra
Super deal for vinyl enthusiasts. An unlimited source of pure RO water for cleaning or rinsing your records. Basically its an Aquaguard RO water purifier and can handle water TDS levels upto 500 ppm. Has served me well, now gotta go since I've moved to an area that requires a higher TDS ratings unit, which I've bought. Has been serviced regularly under contract, has all the internal and external purifier candles/units replaced 6-8 months back. All you'll need to do is get the Eureka guys to come over, install it on your wall and give it a service. Comes with original packing, all fittings, pipes etc.
Can also be used for drinking water when you want to take a break from washing records :ohyeah:
Pick up at Whitefield. Can also be dropped (from my 4th floor window with you standing down, but you have to be a darn good catcher!)
hi mate can I take this?
Hi Kittu,
May I have the Airtel HD box? Please PM me your details and I will collect them from you, if no one is before me in the queue.
Vinod
