3D blu-ray player with media capabilities, region free?
anm
New Delhi, India
please suggest a blu-ray player that can also stream from network and play 3D files also. It would be GREAT if it can play ISOs with navigation (my oppo 95 can't do that).
But a cheap blu-ray player, with 3D media playback that can also be made region free is what I am looking for. I need to order it in the US so amazon/ best buy etc links are welcome.
I doubt whether ISO's can be played by most standard BDPs, leave alone Panasonic. As far as I believe, to play ISO, HTPC is the best option.
The only BD player capable to play ISOs is Oppo 93/95 with older firmware. Bluray Association forced Oppo to remove that functionality, then lateron forced MediaTek (decoding chip maker for Oppo) to remove that from the chip itself.
Rest no possible.
you can try Orei Blue ray player from Amazon. It is region free, plays 3D, has ethernet port, you name it has got it. It is very cheap as well. I am quite happy with its performance.
