Of course. It's a small thing!
Thanks Ashish. I'll PM you.
The BPL Worldspace Receivers are still available for FREE!
Also giving away a very interesting product - Creative Audigy 2 ZS Notebook (PCMCIA Sound Card for Laptops). I haven't used it in ages but it works. It is 7.1 Channel, 24-bit, 192 Khz, DVD-Audio Capable sound card. Comes with a soft plastic case, the cable adapter for 7.1 channel output, Driver CD, a DVD-Audio sampler.
Pictures:
I found an unused Thorens TD150 belt while clearing out some stuff. This belt was bought in the early 80's as a spare and never used . It looks to be in good condition and is still pliant . The belt if I am not mistaken will fit the TD160/145 Thorens TT's also.
My TD150 is long gone. Anyone who wants the belt can have it.
Rajiv
I'mm timing this one. I reckon this will be gone in minutes.
Gone.
Rajiv
Super Rajiv. I'mm timing this one. I reckon this will be gone in minutes.
I only wish I owned a Thorens
Cheers...
hi mate can I take this?Super deal for vinyl enthusiasts. An unlimited source of pure RO water for cleaning or rinsing your records. Basically its an Aquaguard RO water purifier and can handle water TDS levels upto 500 ppm. Has served me well, now gotta go since I've moved to an area that requires a higher TDS ratings unit, which I've bought. Has been serviced regularly under contract, has all the internal and external purifier candles/units replaced 6-8 months back. All you'll need to do is get the Eureka guys to come over, install it on your wall and give it a service. Comes with original packing, all fittings, pipes etc.
Can also be used for drinking water when you want to take a break from washing recordshyeah:
Pick up at Whitefield. Can also be dropped (from my 4th floor window with you standing down, but you have to be a darn good catcher!)
I have an Airtel HD (Multiroom) setup for a give away in bangalore. If any one wants and are willing to transfer it on their name , PM me. No dues on the connection and I switched to Tatasky+ hd long back , these are lying idle.
