DIY Headphone stands - SoundFoundations
magma
recently i built a pair of stands for a couple friends
i realized they can be DIY'ed pretty easily
here's how i did mine
what you need
Solid wood - 1 inch thick
a couple selftapping screws
12mm black glass 5.5inch by 5.5inch
Some sand paper
Polish
Process
Cut out the wood using a router or jig saw - or hell, just get it cut from where you buy it!
6*6 inch - 1pc
5.5 * 10 inch - 1pc
use a file and cut out the notch in the centre of the longer piece on the top side leaving 6mm either side
the notch makes sure the headphones dont slip off
centre the taller piece on the sqaure base using the self tapping screws
sand of for a smooth finish
get the stand polished natural and use melamine if possible
Stick the glass to the base
The glass helps keeping the CG down and making the base heavy so the stand doesnt topple while using
Youre DONE!
here are some others one can try
Google Image Result for http://www.wooaudio.com/images/fullsize/hps2t-slv-headphones.jpg
Google Image Result for http://www.mains-cables-r-us.co.uk/1552-thickbox_default/oscars-audio-headphone-stands.jpg
Google Image Result for http://www.mains-cables-r-us.co.uk/1559-thickbox_default/oscars-audio-headphone-stands.jpg
Google Image Result for http://i01.i.aliimg.com/wsphoto/v9/729885291_1/Wooden-Omega-font-b-Headphone-b-font-Display-font-b-stand-b-font-font-b-Headphone.jpg
Very nice. Elegance in simplicity :)
I'm not much of a woodworker, but probably a chisel should be used to cut the notch, and self-tapping screws are for sheet-metal work, ordinary wood screws are for wood.
Wow! Laminated moulding!
can be done
Impressive! But isn't a disproportionate amount of work to set up the jig/moulds unless sufficient numbers are being made?
(I recently watched a YouTube video about how Steinway Grand Pianos are built. The case is made in exactly the same way)
I'm really impressed too!:)
Approximation will do- I guess you can figure out the size based on the headphones which are kept on them..
Although a word of caution (not a reflection on your quality, which is usually great), but I've seen some Chinese copies which have very rough edges on the bottom where you have to cut the molding off.
OK the seive king copy is in production
will be done in black plexi - high gloss (similar to pic below but in black )
if there are more than 5 members who confirm
all get a discount
should work out to 1/6 th or 1/7th the MRP of the omega/s
the first batch is in
10mm clear Plexi though
intrested Fm's can contact me for delivery etc
