Yes, spoke and texted Ashish couple of times too - he sure promised to get back but somehow missed.. not sure if he has any stock related issues..![]()
There shouldn't be an issue if you have region free/all region disc.You can add a mod kit later though.Are the Oppo players obtained from Indian sellers Region A locked or Region free for both DVDs and Blu-rays?
Thanks! I have a mix of discs(from amazon.com/uk). I do have a region free Oppo 83 which does its job well.
I am about to set up a dedicated HT setup in my basement so was wondering if I should buy the next Oppo locally or get it from US.
How easy is it to add mod kit - soldering skills, et all?
Both types are available form indian dealers - locked and region free. The free one ofcourse comes at higher price.
For DVDs Oppo is region free . even if not, it can be easily made in seconds. Just a matter of a 2 second free software (u ll get by googling) download and playing it via CD on the BDP.
For Blu Rays two types of mods are available - 1) Soldering (Costly) in which no Code input from remote is required and will permanently be region free. 2) other one (Less costly) a simple hardware kit connection to player -can be easily done by user also which will need a code every time u wanna change region.
Avenue sound sells both types of Oppo players and makes both kinds of region free mods on request.
Thanks! Will check with avenue sound with regards to this? Do you by any chance know how much 103 costs with/without mods?
You can rip other region movies on Hard disc and oppo can read them easily.Thanks! I have a mix of discs(from amazon.com/uk). I do have a region free Oppo 83 which does its job well.
I have never ripped the BD's as of yet. Will probably get to it sometime soon. Thanks for the ebay link. Looks kinda interesting but costly! Let's see how it goes. Will keep you posted. Thanks!You can rip other region movies on Hard disc and oppo can read them easily.
Some of mod kits are without soldering.Just press fit.
OPPO BDP 93 95 103 105 Mod Kit Furutech IEC R Mundorf Silver Gold Wire 898072002110 | eBay
