Imp things when you buy anything from japan -
Japan Radio (The FM band in Japan is 7690 MHz), one can not use indian FM channel.
you can try with FM antenna sold by yamaha in india. But it may not work (firmware limitation)
Power supply (Japan 100V)
can be solved by transformer - easily done in india
Language support
Yamaha supports ENGLISH so no worries
usually products supporting eng language are costly in Japan (not a case with Yamaha AVR)
I am getting YAMAHA RX-V475 for 36700 ...... worth ??? though its like 27K in US, in indian amazon its 47K ..... not sure what price delhi dealer might put in .... what do you say
its available at 34.2k..on ebay after considering the max discount of 2.5k ending on 31st jan'14..plus one can buy on emi...:licklips:
Link link link link link. Quick I might grab the deal.
link is as follows:
YAMAHA RX-V475 HOME THEATRE RECEIVER | eBay
further apply ur discount code to get additional 2.5k..
@sam9s .. it does not have 2 sub pre-out however the deal is very good.
go ahead if this solves your purpose. only reason going for 575 was sub pre out and few other gadgetry. price is very good and try to get some Ebay discount coupon and make it a deal.![]()
