You can certainly put an add.Those who dont want 3D will look for WDTV.
How is KDLinks 720 overall performance?3D?Can you post some images?
It is early days with the KDLinks for me. Early impressions are good. Some early observations:
1. Decent UI, but quite clunky. Screens are quite well laid out and transitions are decent
2. Some HDMI handshake problems (?) observed with the projector. Starting a play it often resyncs. Take 5-7 secs but hugely annoying. This might be a issue with my settings. Need to look into it.
3. Read speed is quite fast. Am using only with external USB drive thus far (internal is on order).
4. Haven't tried network shares yet. Have read about a few problems in read/ write to the device over the network
5. Network connects quickly and performs well. If you enjoy typing with the remote, you will have a great YouTube experience
6. Remote is largish and well laid out. Does not take much getting used to. Most of the buttons are useless though, or I have not yet found any uses for them
7. 3D- Works fairly well out of the box. I had no issues with running full 3D ISOs. Had some issues with 3D OU not working properly (was getting a reflection of the image, giving me a headache). Nothing which cannot be worked out, and duly was. 3D experience with the projector is spectacular.
8. Plays ALL file types. I haven't tested the DTS-MA or DolbyTruHD sound yet, but specs say it supports. I have files. Will test over the weekend.
What else....not much actually. Initial setup is simple and straightforward (have not had to refer to the user manual as yet). HDMI cable is included with the device, batteries for the remote (AAA) are not- go figure
I have not taken any pictures thus far. Will try over the weekend and share.
