Shivam
Hi Shivam,
I use AP Bookshelf speakers, and it gives nice bass response, could you please share the specs of your speakers and also upload pics or weblink showing the speakers
Also what is the size of the Driver ?, and what kind of driver is it ?
Tanoj
Old Vifa drivers (used to be scanspeak then) !
The bass that I miss is mainly in some of the classical works. For most of the jazz, blues and other genres the mid-bass is usually good.
IMHO for 2-channel music, getting the sub to match the speed is most important. Timbre and tonality comes a distant second...Like most of pointed above, 2 subs are better than one...
Finding the right sub to suit your needs is usually tougher and more expensive than looking at a speaker with better bass response. My money would go to trying a different speaker than going for a sub...
Unfortunately going for a different speaker is difficult since it is an active setup. Upgrading the whole setup is beyond my budget at present.
