INR 50K max.
Any suggestions ?
Experience is limited on movie subs only, apologies.
INR 50K max.
Any suggestions ?
Shivam,
What speaker cables are you using? I have found that sometimes cables can choke the sound especially in the LF as you are describing. Of course this is no replacement for a sub but worth a shot. I doubt that the amps don't have the power to give you enough bass.
Also actives are very correct in terms of what is coming from your source. You will not get the mid/bass bloom that you get from passive setups.
Best Regards.
One thing I learnt only recently, is that bass traps, despite the name, do not reduce bass, they increase it! Interesting stuff!
I guess there is a difference between boom-boom that is good enough for HT, and bass that is good for hifi music.
Going back to first post... when you say only down to 60Hz, is this based on the specifications for the speakers, on listening tests to music, or listening tests to test tones?
@Shivam
You could also look at SVS sealed subs which are locally available I believe. SB1000 comes roughly within your budget though you are better off with the latest SB2000 (if you are little flexible on the budget) that is supposed to be better than even SB12 NSD. You could also consider Genelec 5040b which comes in your budget, doesn't go deep but fills the gap that you are primarily missing with great authority [ do not underestimate it by looking at its size!]. Also you could scout for some used Sunfire subs...
Lol Thad....I know you are not into HT that's why I took the liberty.
What indeed is scarce (based on the scarcity of discussions on it) are HT guys who understand the problems of bass and ever more scarce are those who fight to tame it! So your point is valid to a great extent.
Do you have specifications for the frequency range of the speakers? I have to admit that such specs can be taken with a pinch of salt for commercial models, especially when there is not +/-dB qualifier, but it should mean something for monitors, etc.Shivam said:I used a Denon test tones CD. I could hear the 60Hz tone at normal listening volumes from my sitting place but not the 50Hz. (I have normal hearing.)
Yes there is a difference. But then, for people like me, it is equally annoying to hear what is not there in the content, be it movies or music. Agreed that movies add extra dosages of bass that is not natural but we can clearly make out the unwanted reinforcement of some bass frequencies due to room interactions or limitations of the sub and that does spoil the experience. We do not really know how an explosion feels like but we do know the boom bass was not recorded or intended. A clean, tight and textured bass is desirable for both movies and music and only difference is that movies need them to be louder and deeper. Why do people generally go for ported subs for HT? Not because they are OK with a little loose bass but a tight and musical bass that goes that low and deep are prohibitively expensive. BTW, do not forget music videos.Well, Santy, there is a difference between fidelity to the cinema experience, and fidelity to the instrumental musical experience, right? I put my foot in it, but that is what I had in mind.
I have had great challenge in integrating a sub with frequencies above 40hz. If I could go back in time I would buy a sub with a driver that uses the same material for its driver as the main speaker. I.e metal for metal, paper for paper, kevlar sub for kevlar speakers etc.
@60-70hz you are going to hear a difference in tonality and timbre when the sub is switched on or off. At least I do.
G0bble
I am planning to set the cross-over at about 40-50 Hz so that the roll off from the sub and the speakers complement each other and have a flat response when working together.
It has been a few months since I heard a couple of Bach's organ works and felt something missing in my system. It seems that my system (AP active with bookshelves) plays sounds upto 60 Hz fairly well but almost nothing below it.
I tested the system using a Denon test tones CD and the test tones below 60 Hz are very faintly audible upto about 50 Hz and below that they are not audible without changing the gain.
Old Vifa drivers (used to be scanspeak then) !
If your main speakers are ducted , you could seal the duct giving you a second order response ( and rolling off earlier , like maybe 90 Hz ). This makes it very easy to design a matched electronic crossover to give you an accurate Linkwitz Riley response.
I'm surprised by your experience! These are the very same speakers (MS101) that I too had and they use 6.25" PP cone Vifa drivers as mid bass units. As per the specs they go down to 45 Hz and I'm thoroughly convinced that they do. I remember playing LF demo tracks that GeorgeO shared with me. I was amazed at how the LF was played by the puny looking drivers! The cone excursion was abnormal but the LFE was mind boggling.
There must be something wrong somewhere. Could it be the Xover? Don't know.
I hope you played around with speaker placement like pushing the speakers closer to the corners and failed to elicit desired response.
ReallyHow [do bass traps not reduce bass, they increase it!]?
I'm no scientist but speaking from theory learnt at High School and of course the net. As per my understanding,I remember the thing in physics at school where we can see that two waves meeting either combine as one bigger wave or else cancel to nothing.
I am going on theory and second-hand reports. No chance yet to have tries out in practice. But it is interesting stuff.
