Hello all expert DIY Ppl,
My excellent performer Heco victa 301 is down from few days ago due to damage of Mid/Bass driver(due to Improper handling in my absence) :sad:
As per the information written on back side of driver its part name is 'heco s-kp 480 d 170'.
I tried many possibilities of getting this part form Germany but no luck.
Finally I have decided to get it replaced with suitable drivers available locally in India and keeping other components like twitter , crossovers unchanged.
I was not able to get original specs for the driver but below is specification for speaker pair.
Mid/bass Driver size 170 mm
Power handling (RMS / max.) 80/150 Watt
Impedance 4 - 8 ohms
Frequency range 34-38000 Hz
Crossover frequency 3200 Hz
Recommended amplifier power 30 - 150 Watt
Efficiency 90 dB
Please help me for finding replacement to this driver.
- I am changing Mid/Bass driver from both speakers
- My budget is 3K INR per driver
- Original drives has 8 screw holes hence it will be better if i get same for replacement driver
So far I was able to find only this which is somewhat closer
Peerless - 6.5" Kevlar Woofer - M16KI
Thanks In advance.
Efficiency 90 dB
Thanks In advance.
