The Giveaway Thread
I have the following Cables / Splitter for giveaway. Pick-up from my office at Nariman Point, Mumbai or Wanawadi, Pune during week end. In case you would like to donate, it will go towards charity:
1) 1 Pair of DAC PCOCC Speaker Cables 2 mtrs. with Gold Banana Plugs (one
end).
2) 1 Pair of DAC Shielded Interconnects 1.5 mtrs. with Gold plugs.
3) Monster Component Video Cable with Gold Plugs
4) Marantz Component Video Cable
5) Marantz Composite Cable
6) Toslink Optical Cable
7) Original Bose 3.5 mm to 2 RCA Cable
8) 3 Way HDMI Splitter with switch (3 inputs, 1 output).
end).
Can I get these?
possible to get these ? can collect -
I have a give away GR 333 Pioneer equilizer in great working condition.... PM me if someone interested.
Shipped the N/W Media Rcvr and the Saikat has rcd the package.
I hope its come in good condition and you could put it to good use..
Thanks..
Thanks for the kind gesture Kanna. It was really pleasure to have received this for nothing. I have replaced the wifi antenna (courtesy the abundance of unused wifi PCI adapters I used to use more then 3 years back). I am at present testing this against different media servers. Found the DLink's own media server sucks but TVersity works very well with it. Will post more updates soon. Thanks again dear :)
end).
All these are taken by Darshan & Spiro. Can be treated as closed.
Odd items and some components for giveaway.
Solid aluminum pointer knobs with knurled grip:
Dimensions: knob diameter - 22mm; Outer rim diameter - 29mm; height -25mm; Shaft hole: 6mm
Bakelite handles 105mm long with 90mm fixing centers:
DIY amp cabinet in MS with teak wood sides and 8 mm aluminum face plate unfinished:
Internal dimensions in mm: W360 X D300 X H90
DIY book shelf speaker enclosures:
MDF and teakwood baffle, 6 1/2 woofer cutout and one peerless dome tweeter. Outer dimensions in mm: H300 X D230 X W210
JBL subwoofer plate amp (modified):
Scandyna Micro-Sub subwoofer Plate Amps:
Scandyna Micro-Sub subwoofer enclosures:(2 nos.)
Cambridge Audio AZUR remote control: Cambridge Audio Azur Amp CD V2 0 Remote Control RC 340AC RC 540AC RC 640AC | eBay
Sherwood remote control:
RM-111, RM-112, RM-108, CDC 80
A box (10+) of pre recorded VHS films in OK condition.
Some spare capacitors for passive crossovers:
1.5K 250V 2.0uF 400V 2.2uF 400V 1+1uF 400V
TO-3 Transistor Insulating Cover:
AKAI active sub woofer: (working)
Speaker grills (metal) PA type: 12 (2 nos.) and 5 1/4 (4 nos.)
Mordaunt Short CS-1 enclosure with (Tweeter & Xover)
@Hydrovac : if the aluminium faced cabinet is still available, I would love to have it with a couple of knurled knobs. Thanks in advance.
