hi friends,
i have been more of a lurker on this forum and i particularly like DIY section
. i have been thinking of building a class a amplifier for long and finally i have decided to take a first step.
i do not understand the complete nitty-gritties of amplifier working yet. after some readup on net [this forum and diyaudio] i have understood few stuffs - though it is still a long way to go. couple of DIY Class a amp threads by experienced members have started off with final product display and some change later on. but this one going to be slow starter as i am trying understand and also procuring the required parts. so please bear with me! and also i would need lot of guidance and help
now about the amp - i have chosen Hiraga 30W Super Class A amp design as,
-i felt the schematics are comparatively simple
-availability of spares
-and relatively small size of the amp itself [i am planning to build it as a dual mono though - separate chassis]
queries!
for amplifier PCB, i am planning to order them from Jim's audio - only PCB and not the entire kit. [i have exchanged couple PMs with FMs Bibin and Sachin in this regard. both of them suggested LeMonstre [8W] version. but i want to try the 30W version.]
now out of the 2 PCBs listed on ebay.com which do you suggest?
this one fairly simple..
Stereo Amplifer PCB Hiraga Super 30W Class A | eBay
the one with Kubota rebulator [earlier i thought it is a physical device need to be procured separattely. later realised that the PCB has the circuit built in
Stereo Amplifer PCB Hiraga Super 30W Class A w Current Source Kubota Reg | eBay
in case of the first PCB, won't the bank of capacitors take care of filtering? my worry is about availability of parts and complexity of execution case of Kubota PCB.
o/p transistor:
2SC5200/2SA1493 pair or something else?
power supply:
one of the builds on diyaudio [sergiu's on diyaudio] uses 300VA 25 0 25 toroidal. i am planning to stick to the specified ratings [one for each channel]. any suggestions in this regard?
capacitor bank:
6X22000uF for each channel
please help me with you responses!
PS: i am planning to build a passive speaker later for this amp. for now i have an Aiwa passive stereo speakers [rated at 6ohms - that came with 30W pc Aiwa mini hifi] for testing.
queries!
o/p transistor:
power supply:
capacitor bank:
