Help needed on video editing - Google map
arnprasad
Vijayangar, Bangalore
Hi..I am planning a trek to Kudremukh next week and I want to know the easiest way to show my way from bangalore to Kalasa to Samse to Mullodi - all via vehicle and long distances and finally my trek from Mullodi to Kudremukh peak.
Whenever any tragedy happens I see this on new channels when they use Google maps/Earth to fly through over an area and other such effects.
I did try google earth flythrough but the process i went through 3 years back was slow and painful.
Any help on how to show the route on a google map in a video format would be great. Thx
I think only way to use screen recording on mobile with Google map , then overlay map with your video on post editing ...
If you are using Gopro , then Gopro records some GPS telemetry data with videos where you may use this for map overlay in post editing i think.
If GPS metadata is embedded in the camera recorded video file you can use this https://goprotelemetryextractor.com/free/
Anything above hero5 should work - you have to turn on gps wait for signal lock icon then only hit record button. It works with non GoPro files as well.
Tip: when you use the free version and add a big 4gb file to upload it is only extracting gps data not the whole video file. The click the appropriate buttons to Download a KML or gpx file and import into google earth. There are other videos for how to do good stuff with google earth using imported files...
Any help on how to show the route on a google map in a video format would be great capcut mod apk download. Thx
Use Google Earth Pro to record a flythrough of your route. Plot your path using the Path tool, then use the Record Tour feature to capture the journey. Adjust the speed, save the tour, and export it as a video. If Google Earth is too slow, try Google My Maps for a simpler animated route or use video editing software like After Effects for custom animations.
