The Giveaway Thread
I have handed over the following items to DTDC courier for delivery to respective FMs.
Matrix Trilogy Bluray
HDMI Cable
Mama Mia Bluray.
I shall pm the tracking number. You should expect the delivery by Tuesday.
USB to Serial cable and RAM are still available.
Tracking numbers pm'd to jaivelu, Vinod.R and captrajesh.
Thank you very much Vidyabhushan for taking the trouble to courier the HDMI cable to me. Lots of thanks.
I will let you know once I receive the cable.
Vinod
Hathway SD box, unused for a year is available for local pickup at bangalore with about 10 m cable wire. PM if interested
Got the HDMI cable today.
Thank you very much SatMumbai for the nice new year gift and thanks to Vidyabhushan for taking the trouble of sending it by courier.
So far I did not have a decent HDMI cable, now I do.
Thank you guys for making my day.
Vinod
There has been no action for sometime in this thread, so here goes:
I have a Sanyo Component Music system giveaway. Belonged to a friend of mine. Amp, Tuner works. Tape turns on but needs some service. Entire system needs extreme TLC. Individual items cannot be given separately as they are inter dependent.
Pickup at Thrissur only. Pictures attached. Please PM me.
Not a single person seems to be interested in restoring this Sanyo beauty. Sad. The only reason I picked it is that I wanted it to have a new lease of life otherwise it was going to the scrapped. I do not have the necessary skills and patience, otherwise it is a project I would gladly volunteer.
Anyone gungho enough to pick it up?
Hello! As I am cleaning my AV room nooks, corners and cupboards... lots of unused stuff is coming out. Over the next few days I will probably put up a few things. Here is today's list:
1. AV Input Selector Switch - 3 In 1 Out (RCA Composite) + 4 sets of RCA Composite AV cables.
2. SCART to RCA Composite/SVideo Converter
3. One RCA (male) to Two RCA (female) converter (2 pieces)
4. One RCA (female) to Two RCA (male) converter ( 2 pieces)
5. Emerson MM205S Karaoke Microphone (For use with DVD Players with RCA Composite AV) - Brand new
Photos: https://goo.gl/photos/CzKqhcyrmu13fRuN8
First come first serve basis.
Also have two BPL Diva World space receivers with one set of Aeriel, Remote and Adapter. Have not used in years. I don't know if the service is there or not. Both units power on.
Can I have one World Space receiver with a set of Aerial,Remote and Adapter if there is no one in the queue?I live in Chennai.Is it possible to courier the unit?I will bear the packing and courier charges.
Thanking you,
pksnathan
Thanking you,
pksnathan
You can have it. But please take both. Without a set of accessories what good is just the receiver. I will have to throw it only.
Okay this is for amateur and pro DIYers. This is a Teac MC-DX220i micro hi-fi system (CD, iPod, Radio, Aux) - of course dismantled by me for "educational" purposes :). What is missing are two Satellite drivers and one subwoofer driver and their cabinets. The original ones were damaged long ago. But i have used many different small satellites with it. All the electronics and proprietary connectors are there. And it definitely works. You need to do three things - 1. Make two small satellites (10W 4ohm). I have used 3" peerless drivers and it works perfectly. 2. Make a small subwoofer with a 5 or 5.5" driver (15-20W, 8ohm). Again a peerless SKO130 or MH13 should work great., 3. Reassemble the plate amp and mount it behind the sub. OR. You could convert it into a 2.1 single box with the plate amp at the back. The sleek table top system connects to the plate amp with a single multi pin wire. It draws power from that too. Let me know if it interests anyone.
Hi Aashish- Can i try my hand on this. Can pick from your place a I live in Gurgaon too. I have two spare tymphany drivers 3.5" as well.
Please let me know.
Vinay
Got the following to give away...
1. Garrard SP25 MkIII Got it, tested the motor but never got around servicing it
2. CNC Phono Kit Got it from Sachin but never got around building it
3. Sony Playstation One (SCPH-5552) with the famous AKM DAC. I got it to do the CDP duties. With a basic cleanup of the optical unit, I was getting amazingly low noise floor but a constricted soundstage. I guess the main issue is since it does not have the native RCA out but is converted using an outboard adapter. If you are savvy enough to fiddle with the converter and put better power supply and caps, you could have a killer CDP.
4. 2 Discman (or is it Discmen?) 1 is working fine, needs a bit of cleaning, the other not so working, can be salvaged for parts or maybe you can make it work
5. Givson Bass Guitar do notice the v in the name. Strings changed recently but not really played regularly
These will necessarily have to be picked up from my place. I got a few stuff on sale as well, in case you are picking up something there for shipping, I could try to bundle these along...
Might have a few more things later...
Guys, Items 1 and 2 are still available if anyone wants.
